Scott - post #64. You should try reading.
That's AVO using a GT40-35 turbo? I'd expect that to be a late bloomer on a 4.5l 6.
The Kazuma/TRD s/c also has similar restrictions for CARB compliance/exclusion. What happened to your "lb boost for lb boost" comparo?
Er, happy to do one or the other. Christo has pointed out his comparo is a kit as out of the box delivered, hence why he didn't have a intercooler on the SC comparo. From Carb D490, the comparo should be 4.5psi on the Safari.
I guess to state the obvious for you: Is the Safari kit that you recieve with the Carb compliance sticker, really Carb compliant? Not if it exceeds 4.5psi. The TRD is at 6.5psi.
Now, since I've already baselined my fuel on the SC, there is no question in my mind that additional fuel can be added to the SC and still stay well within the bounds of CVS-75 test procedures as I understand them. I suspect Toyota didn't do this because of cost of kit, but HC emissions on the SC kit has a lot of room to move, and most likely improve Nox and CO. Also, since intercoolers don't change airflow, only air density, those are pretty easy to keep Carb compliant. As a rule, it's the flow that kills Carb exemptions.
As a rule, Carb also likes SC's, because they clamp down on variance by pulley diameter and crank diameter (for example, the TRD kit EO has 3.2in pulley and 7.7 crank pulley defined). As a rule, they don't like turbos, cuz it's too easy to crank boost, it's easy to mod any given turbocharger unit, all using the same defined hair drier.
I also did a quick revisit of my notes vs available turbos on a single turbo applied to the 80. Not much has changed, the biggest problem is finding good compressor efficiency and speed at really low pressure ratios, then not choking the exhaust flow. Finding a turbo that works well at 2-3PR is easy.
I only see one Garrett that appears to be a good fit to the 1FEFZ motor. I also suspect there aren't many that are going to show boost improvements below 2600rpm without choking or surging.
After that revisit, Istill come to the same conclusion that a single turbo isn't *better* than the SC in a intercooled kit at the same boost, only *different*.
That GT-28RS still looks really good for twinsies tho! Come on Dusty, it's time to plug that welder in and go dual water cooled ball bearing man!
ST
