Simple wiring question
castle rock CO
After tearing into my wiring to try to clean up the rats nest under my pedals that the PO had left for me, I now have a new issue that is most likely very simple but I have spent WAY to much time trying to deal with it. The issue is that I know cannot turn on my right turn signal. I have followed all of the wires checked connections, rechecked X10, etc. The rear back up lights also don't seem to be functioning... I checked the ?relay box? on the steering column that is connected to the turn signal lever and disconnected the working Left side with the not working Right side as a quick check for the wires in between there and the lights. The back right signal comes on, but not the front??? I guess I could run new wires from the front to the relay, but I think that it is either a loose connection, or I have a loose connection. If someone can give me a short wiring 101 course, I would appreciate it. My guess is something simple...Once I fix the problem that I created for myself I can now put the wires back where the PO had them but in worse shape.:doh:
The easiest thing is to get a multimeter and figure out where the power stops. Then you know if you are dealing with a bad wire, fuse, switch, relay, connector, etc.,. The list of what could go wrong is pretty long unless you are able to narrow it down. You can pick up a cheap one at a discount tool shop for about $10. If you're not sure how to use it, just play with and you'll figure it out, you can't really mess them up on your truck, not enough juice.
agreed
although there are some workaround the meter is a basic tool you need to be able to use and a big time saver get a meter not a test light or get both
The meter will allow you to do power off resistance checks for shorts, opens, and continuity
I agree...
A multimeter is the first thing that I should have gotten. I appreciate the input I was just hoping that based on the symptoms listed with switching the sides for the signals etc. that someone might recognize something. I checked/replaced the fuses and the wiring is relatively new (painless harness). I will start rechecking tomorrow. I have an offer of $15/hr and a case of fat tire for anyone in the Denver area that wants to lend me a wiring hand. I :censor: hate wiring!!!
Maybe you inadvertently pulled out the wire for the front right turn signal. It is green with a yellow stripe. Find it and plug it back it. This is one of the reasons that you don't fix things that aren't broken. The "rats nest" is stock.
Green wire
Trust me pinhead I know exactly which wire you are referring to and I have swapped out the connector with no fix. Not fixing something that is "not broken" are words to live by. However driving around with wires under the pedals is a mess waiting to happen. I realize that I can either deal with the mess now, or potentially on the trail which will take more time/frustration.
A very high % of problems like you describe are the result of poor grounds. The front and rear turn signal/parking/stop/tail/back-up lights are grounded through the unit's housing where it mounts to the front fender or rear frame cross-member. Some guys will run a separate ground wire from the front parking light stud over to a fender bolt but I think this is sloppy so I just use a large star washer under the lock washer and bolt in the front and I've never had a problem/ Carefully clean the surface under the front fenders where the stud goes through and use some dielectric grease. In the rear, I use star washers under the mounting screws. Also it may help to clean out the bulb sockets thoroughly in the rear lights. When a turn signal lights but doesn't flash on one end, it usually means there's a problem on the other end like a blown bulb, bad ground,etc.
The guys are right on the multi-meter, I never leave home without mine! To check your back-up lights as an example, put her in reverse with the ignition on, remove a back-up bulb and put the red probe on your meter to the bulb of solder in the socket. When you touch the black probe to a good ground (unpainted, unrusted surface) you should read 12 volts. If you do, it means all is OK back to the socket and it probably means you have a bad ground at the housing to the frame. Do a similar check at any light you're having problems with. It you don't read 12 volts, then move upstream to the harness connector, dash switch, etc.
HTH
Pete
What I was looking for
Pete thanks for the great tips. I have checked the bulbs, fuses, wires, etc.. mostly for connections not necessarily current. I have checked the grounds also but this doesn't mean that they are in good shape, and I haven't checked the back bulbs. Thanks for the great advice. Hopefully I will have some good news to report later on today.
Finding the problem is simple, but it isn't necessarily easy.
You turn on the turn signal switch, and look for power (not just voltage) at the bulb. You first check the voltage with all the wires connected. Then you disconnect the wire at the bulb and check for voltage. If there is no voltage with the wire connected and there is about 12V with it disconnected, this tells you that there is a bad or corroded connection upstream (toward the battery). If there is no voltage either way, then the wire is either broken or disconnected. If there is a short upstream, the fuse would have blown.
Then you follow the wire to the next connection up stream. You use the color code to find it. This is where it gets unpleasant, because it is often up under the dash or you have to disassemble the steering column to get to it. Repeat the analysis until you get to the switch. It can't be any further upstream than the switch because the left turns work.
