Ok so got the wiring all fixed on the rear end. All went ok aside from wiring the turn signals in backwards the first time. The weird thing is the left turn indicator works fine at idle, but the right one sticks until I throttle the engine up then it works.
Question is: Should I suck it up and replace the signal relay or is there a way I can tweak the voltage so it works.
BTW my 40 has a 302 conversion, not sure if its a factor.
