side mirror repair
Nice write up! I've always wanted to learn more about soldering & brazing. Would MAPP gas work for the silver brazing? I've got a small oxyacetylene set up but looks like i'd have to get a new torch for the acetylene tank and hose.
thanks again, ty
Ty, MAPP gas should work fine! Thanks for your kind words.
Sorry Pablo Cruise, I'm not familiar with the tailgate issue. Do you have an example?
Yes, as does every other Pig owner. I think the material is the same as the mirror base, and the handle fails inside the gate. I can dig out a broken one and get pictures. There have to be pics of the broken handle in here...
I can try and look around then and see if I can find some pics. The soldering fix might work if the affected area is thick enough. If not, I should check into making a mold of the piece and then casting in a stronger metal. I do bronze, aluminum, and iron casting so maybe that would be another option if I could pull a good mold off of a handle. I'll check the handle on my FJ55 and see if it's the same material as the mirror bases.
