Show me your fire extinguishers!
Reading, MA
I'm shopping around for a fire extinguisher and mount, so I want to see where people mounted them and also how they were mounted. From what I've read, the little 2.5 lbs ones aren't quite big enough. So also tell me what size you chose.
Sent from my iPad using IH8MUD
I have a small FE mounted with the new size quickfist that works perfect for FE's (got it from Southeast overland). I mounted it to the back of my Tuffy Console. It used to mount to my rollbar, but it would be hard to reach it there in an emergency.
Just attached to rollbar, accessible from the rear, also one on the front of rollbar behind driver seat.
5lb'er on a MetalTech cage using 1 large quick fist and 2" conduit hangers isolated from cage w/ left over coolant hoses cut to size.
Cell phone pic btw....
i've got THE hook up for yall on the cheapest quick-release racing quality fire extinguiser mount.....pm "Jduck" on pirate4x4, they are around $20. the mounts that come with your extinguisher are not safe in a rollover.
Was that a type in the price? The one I found from RDM offroad is closer to $120 once you add in the mounting options. Nice piece, but too expensive for me.
I used to have 2 small 2.5lb one mounted to the rollbar (rear passenger side, and front drivers side) using exhaust clamps. I've had to use one in a vehicle fire one time, about the only thing I'd use them for is to get someone out of a burning vehicle, I don't think it'd be able to extinguish even a small engine fire even with a larger one.
I've been meaning to find a way to mount a 2.5 gallon water extinguisher filled with some sort of foam suppressant. I just recently bought some of these fire extinguishers but haven't had a chance to try one yet, but if they work half as good as advertised I'd probably buy a couple more.
I had to use mine and it was a 2.5lb one and I have to say, I didn't get the fire totally out with it. 99% out, but not all the way. I also hit the fire from under the cruiser before trying to open the hood and wasted some powder trying to get the hood open with the extinguisher going off somewhat unaimed for a second or so.
I think it would have been fine if I could have got the hood open right away, but it was VERY hot and I actually burned my hand a little opening it. Either way, I will be replacing it with a larger one.
