should I be worried?
Tucson, AZ
It appearers that there is an oil leak along the edge of what I think is the place where the head bolts to the block. HG seal? I have had this leak since I bought the 80 about a year ago now and it is not a very fast leak but it dose seem to be around a lot of the seam for lack of a better term..It has caused crud to build up on the left hand side
of the distributor if you are facing the engine. Fresh oil is getting shot on the 2" coolant hose coming from the top of the rad. Power is fine and other cruiser heads have said that my engine sounds very good.
I'm a bit worried that I need a new HG. This is not the seal where the valve cover meet the head but rather the next seal down running parallel to it. I will look at me FSM when I get home from work and post pics tomorrow. Seems the more I learn about my LC the more stuff I find to worry about.
Thanks all
Also there is no smoke on startup and no bubbles in the rad or overflow .I have developed a rough Idell but this seemed to coincide with an oil change from an unknown oil and lucas additive to mobil 1 and no lucas.
Thanks all
Check your distributor its probably the o-ring that seals it to the head.
cool thanks I did not think about that possibility. I guess oil could be leaking around it and then traveling along the seal on the head making it look like a head leak.
With the amount of miles you have that o-ring is history mine was at 111k. I'm no expert but HG failure would unlikely leak oil but coolant seepage is a different story. Don't worry that HG will go soon enough mine went 2 months ago but I think you are fine for now.
I in kind of a strange situation ...thing is I have no idea what has been done to my 80 by POs. I'm the third. when I got it the blue fan clutch was installed along with a new front rotors and that is about it as far as the 2nd owner knew. Car fax is clean. there is a chance I guess that the HG has already been done. Since there is a chance all I can really do is wait for it to go because if I did save up the cash to do it / have it done and I found a bright shiny new gasket I would feel like a real chump as the $ could pay for several mods.
I assuming there is no way to tell if it has been done. Aside from tearing it down. Not that I have the skill to attempt a HG repair.
Don't sweat stuff that ain't broke. HG problems aren't guaranteed, no matter what you've heard. Drive the truck, fix problems as they become evident.
-Spike
I've had that leak for about more than 2 years. Last month I put in Rottella 15W 40. I guess that was the last straw. Finally last week The truck went belly up all of a sudden, white smoke, very strong gas smell, absolutely no over heating but misfiring on Cylinder 5 and 4, and all this started to happen on VA rush hour traffic :D. Oil and gas started to drip from the exhaust too. Yeah I checked the wiring harness with volt meter and every thing came out good. The injectors (4 and 5) seemed to have some trouble too. So I decided to dig in there and get to the HG. Ordered the parts from Dan last week. Should have the head off this weekend and will drop it off to the machine shop. Also will clean the injectors and all that.
Just keep an eye, don't get stranded like me. It might not be a bad idea to do some kind of diagnostic check/test to see how far along are you on the HG (if that's the case).
Good luck:cheers:
If it is leaking above the head at the base of the valve cover, then its a valve cover gasket. Common problem and easy to fix. Should replace the 6 spark plug grommets while your in there.
From what I can see the only preventive maintenance the PO did on my 80 was keep the gas tank from going empty! I found a lot of neglected things but these motors can take it better than others. Spike is right just fix it as it breaks. Didn't mean to spook you about the HG but when it goes it goes various MUD members had failure at all sorts of mileage. If you wanted to do it as PM there are a lot of people here to help you along the way they have for me.
George
