Should I be worried about the cracked hose on the left? Also what is the diagnosis port in the second picture? My 80 is a 95 but it says it is OBD2 compliant and it has a port for that in the fuse panel so what is this one? Thanks.
There you have it. The FSM makes great bathroom reading.This is the 80 forum, so concern is a given.
That is a breather hose, could consider replacing it?
The diagnosis connector is where the system is jumpered to put it in the diagnosis mode to set timing, etc.
I would replace the PCV valve and grommet and the hoses with OEM. The OEM hoses are shaped to fit under the hood insulation, not sure if the aftermarket ones are, but the OEM ones are cheap, so why not just get those?
