Short Circuit? - Won't start
My 92 FJ-80 is having some sort of an electrical problem when I go to start it. The battery is fully charged and when they key is in everything looks good on the dash. When I turn the key to start the engine power cuts out completely and I have to remove the key and put it back in to get power back to the dash. On one attempt to start the car, I heard a loud series of clicks coming from behind the stereo.
Any idea what could be going on? I haven't done any electrical work before so not sure how to get started.
Thanks
How do you know the battery is good?
I charged it up on a tester/charger in the house, and I have full power when the ignition is in the acc position, its only when I turn it to start the car that it looses all power
Battery may still be bad, the load may be showing its shortcomings. Maybe have a auto parts tore do a load test on the battery (usually they do it for free).
Had similar problems a while ago, turned out to be a combo of bad battery and bad connections.
X2, load-test the battery.
If it turns out the battery and connections are good, check the following...
...make sure your neutral-park cut out switch is not faulty.
...make sure your ignition switch is not broken in the "start" mode, where the contacts are either worn or broken.
Usually the way the ignition systems work is that when the key moves over to the start position, everything runs through that starter contact, so if the starter contacts in the ignition are worn or broken, it should just go dead as soon as you flip over to start, then come back alive as you flip back to ignition.
If if doesn't come back alive as you flip back to ignition, then it's probably something else. The more I think about it, a bad battery, bad connection, or shorted out starter solenoid is where I'd lean first.
Good luck.
