Shore Power
Oceanside, Ca
Every trip, I always turn my fridge on the night before. Run a extension cord from the garage thru the rear
window. Or, if we stop at a campground, the same. Never liked leaving the window open all night, so how about rv shore power. Ordered this plug: http://www.amazon.com/Leviton-5278-CWP-Receptacle-Industrial-Grounding/dp/B003ATXIBG?tag=ihco-20
Drilled 1 3/4" hole, mounted plug on the PS rear panel. Ran wire/ mounted interior plug and in less than a hour, all set ready to go.
now someone needs to make a kit to make the AC compressor and cabin blower to run off of shore power
window. Or, if we stop at a campground, the same. Never liked leaving the window open all night, so how about rv shore power. Ordered this plug: Leviton 5278-CWP 15 Amp, 125 Volt, Power Inlet Receptacle, Straight Blade, Industrial Grade, Grounding, Gray - Rv Receptacles - Amazon.com
View attachment 1240149 View attachment 1240150 View attachment 1240151 View attachment 1240152 View attachment 1240153
Nice!
Does it charge your batteries also?
Been on my project list for a while needs to get closer to the top:rolleyes:
Like a lot of things in life, how you place your receptacle is a personal choice. The OP favors the RV look and I kind of like it. Joey has already thought of this...I like that, too. And a Sawzall is one of my favorite tools...but obviously there are too many movies about demolition around right now. Don't let that thing near my 80, because I've never needed that sort of, urr, intervention. I've already left a hole I need to dress up inside with my 12 v fridge plugs in, so will think about this. We don't get to many campsites fancy enough for that, I suspect. But good show.:bounce: Great topic.
I plan on adding this charger. I will cut the plug off and hard wire it in.
Probably mount in cabin, PS rear.
@greentruck I agree, not many places I stay have power...but I think I will like it at home.
I only know about them because we just built an underground mine ambulance and used one of those, they're pretty neat. Kick the cord out a good distance. You're right though, they are large. Definitely not low profile, very industrial. At least theres no concern of driving off with the cord plugged in. I do that with my block heater several times every winter. I get home to find the extension cord dragged all the way down the drive way. Oops. Guess I need one myself...
