As @KLF mentioned, I put a friends GoPro on my head for an install video. I'm not super happy with how it came out, but it was a learning lesson for me on what I need to do differently next time. I can build you a 1,500 hp motor, win a war, live off the land, but video editing is pretty rough for me...
So don't use a lift, it's just terrible and the lift arms are in the way, use a floor jack and it is much, much faster. The lollipops are easy if you guide the lollipop in with one hand and find it with your finger instead of the bolt.
Trying to find two objects that your brain has no feeling in, while inside a frame rail is tough. Use your finger to guide the lollipop into the hole, then once the lollipop in seated, remove your guide finger and grab a bolt, it will go right in. If you have any mechanic who understands engine work, he will understand this trick. Which does full circle to the cost of the install.
It sounds pretty reasonable to me. At BB I charge about 2/3s of that prices, but that is because I know exactly how to do the install as efficiently as possible, and it was also an incentive to get as many 200s in the shop for refinement. As Bud says, "if we build armor off of five trucks, it will never fit. 60, 60 of the same truck is the minimum to ensure fitment."
I would never fault another company for charging more for a 3d party's products, and you will naturally slow down. Plus if the truck has rust, mud, or that terrible fluid film all over the bottom, it's going to slow down. I don't charge extra for that, I just clean the rust up, and re-enamel while i'm under there. I also do my little KDSS protection thing I do so the valves never rust, because... why not? It's a cruiser, let's do it right and take care of it.
I'm hoping that the video, helps I just have to get another body-of-frame build out the door, then I can edit this video. Ugh... I need more time, I haven't even been able to make a simple little banner to finally because a vendor on here.
It's not any harder than another slider I've installed on my personal 200, just different. I installed
@Sac Cerevisiae sliders in the gravel packing lot across from LCDC 2019 with no jack 3 hours prior to the opening BBQ event. Took 45 minutes for the driver side, 30 minutes for the passenger slide, then I ran back to my camp, took a shower, and showed up to say hey.
Plan for 4 hours driver side, and 2 hours, passenger side if you have never done it. All the fasteners a put together from Chip and are numbered so it takes the guess work out of where they go.
