Will,
Hey buddy. Yeah i am still here. Need to get my rig back into great condition. Have had an issue for some time. My mechanic sent it to an alignment shop where it was diagnosed as having a bent (forward) axle on the left side. That is total BS.
Greg, do you have the figures from the alignment. Pretty easy to call BS just because you never hit anything, but I can assure you it does not take much to bend a 80 front axle. Have you ever hit anything? You say you never hit anything hard enough?
The tire wear is obviously indicating something is wrong. It might be bent links. Have you owned the truck since new. Is this a new thing that happened or did it always do it. If it is new, what happened just before this appeared?
It needs someone who is an alignment expert to adjust the pan hard rods and get everything centralized again.
I would say an alignment shop is an expert, but you don't believe them If you do not have another set of number, get them, otherwise everyone is shooting in the dark. Cost $70/$80 or less to get an alignment reading. Tell them you don't want anything adjusted. Just a printout.
Also there is a winding noise somewhere in the back which is obviously caused from this problem.
How do you determine this?
I thought that it might be coming from inside the diff but my mechanic said that it is the left rear wheel bearing.
Is this from inspection or just speculation?
Anyway, the tires have worn extremely strangely so i am going to replace them now so that tire noise will eliminate some of the overall noise occuring.
Alvaro mentioned bent lower rear control arm. Is this the case?
It is really easy to get frustrated and disappointed in shops, however it would help if all the information is put on the table and have the shop evaluate it. I can not tell you how many times we spend enless hours talking about issues, only for the customer to mention something that he thought was incedental, but actually important information for us to know.
Like, I have OME 2.5 on my truck, it wanders all over. We go through everything to figure out what is going on, then the customer says, "Oh, I also put mr gasket spacers in. That doesn't effect it, or does it?"
