Shocks Removal/Installation question
Cool thread I plan on doing mine soon. I hope itll fix a heavy lean. How hard are the front ones? The lean isn't as noticeable in the pic. (Heavy to drivers side) and the rig looks a lot worse than that picture suggests.:):D
Shock won't fix a lean. most likely its the springs. PS in calif. we don't have the issue removing bolts [we don't salt the roads] I was able to install gears, shock,spring, & all soft break line with out any penetrating oil and no striped or broken bolts took the front down to the bear housing.
IF your truck did not come from the salt belt you won't have issues. If you are not saving your old shocks use channel locks to hold the top of the shocks to remove the top bolts. good luck
If you are sticking with stick height then you really can't beat OEM Tokico shocks. Price and performance they are as good as they come. Many of us have tried Biletein, OME, Rancho and OEM.
Between the OEM shocks and Bilstain, which one is more firm?
I can't remember.
The LX450 shocks are squishy. The FZJ80 shocks are firmer. At least this is my understanding. It may just be the springs though...I'm not an expert by any means. I haven't run Bilsteins on my 80 since around 2000. I wheeled it pretty hard back then and didn't like it.
it depends on the Bilstein series you have and valving on those ..
4600 series is a waste of money! Just go oem. Cheaper but watch out on corrugated roads, tend to fade rather fast.
