Shocks question
Plant City, Florida
i want to replace my shocks. I was told the 40 had a 3” Rancho lift (but i only see them listing a 2.5”). So I’m not sure how long the shocks need to be. This is a pic of the shocks. Does this number tell me anything? Would the current length between mounting points help? Or is 2.5-3” lift not matter on the shocks?
Better yet, measure the shock mounts, stud to stud, and that’s your static length. The rear should be 2 inches longer than the front. Then look at the shocks min and max stroke and try and find shocks as close to the middle as you can. Reference; my 4 inch lifted 40 has 18 in front and 20 in rear static shock lengths. The new Bilstiens I just installed were for 3 or 4 inch lift so my guess is yours is pretty close to same. 1/2 inch is not enough to worry about in which lift you have in regards to shock lengths IMO.
Thanks I will measure them later today.
Oh I forgot to mention that the front and rear shocks were different part numbers as the rear shock body is longer and so is the stroke.
