Shims help please
Yuma az
Ok if i want to put a set of shims on my rear axel
do i replace the stud on the leaf spring
because if the shims are added the stud isnt long enought to go though shims
I bought my shims from CCOT and they came with the extended stud. Worked great...
If you're talking about the spring pin bolt head not going through the spring perch and shims, I had the same problem. You could probably weld an extension on the bolt head. What I did was a little easier. I grabbed a couple of extra nuts, filed out the threads so they would slip over the end of thebolt and snug up against the bolt head. Instant head extension. You have to take the old spring pin bolt out to do this, but that's not too tough. HTH, ty
