Shifting issue
olympia, washington
After years of looking, I finally picked up a 96 fzj80 with 166000 miles. I has a 3" OME lift, 488's, 35's, Cruisin offroad sliders and rear bumper, a Detroit and a Trutrack. It looks like it has been wheeled but not hammered. I picked it up for $6500. The only issue I have found is when I'm driving about 30 mph and floor it, the engine feels like it goes into neutral and just free revs up to redline. I have to let off before it finds a gear. I can shift in manually and it works fine. The tranny fluid looks good and is at the correct level. I tightened up the kick down linkage a little bit but did not see a change. I also played around with the TPS but ended up putting it back where I started. Everything else about the tranny feels good. Any thoughts or ideas would be appreciated.
Any codes? Meaning is the Check Engine Light on? If it is on after starting the engine, you have trouble codes stored. Check that the CEL comes on when the ignition is first turned on before the cranking position. Being a new car to you, just trying to cover the basics. And by the way, :flipoff2: Welcome.
if it shift fine manually it's probably the shift solenoids for 2nd to 3rd
