The shifter in my truck that problam of pivoting around in any position, I took the cilindrical plastic bushing off another shifter but had no effect ( the other was pretty worn), The truck has a 5 speed and the shifter is the type where you need to push down the retaining collar and turn it about 1/8 turn to get it out. Everything looks normal, the housing has two pins that the shifter mounts to they are in good shape with no signs of wear, the shifter itself has just a liitle wear where it mounts on the two pins , other than that I can't figure out what the problam is, seems if there was more pressure on the spring it would work, could something, a washer , spring collar, or some sort of bushing be disentigrated and missing?
If someone could shed some light on this it would be most appriciated, maybe an exploded drawing or a photo of a known complete shifter assembly would be great.
