Shhhhhhhhhhhhh!!!
Oxford, Mississippi
hey guys
Im new to the 40 chat section i have an 89 fj62 but recentley have taken over my older brothers 1978 fj40 since he got a new truck and moved to florida. It is my daily driver and i was just curious if there was anyway that i could make it a little quiter on the inside so i could actually have a converstaion with someone while i drive...any ideas will help...appreciate it!
Re-felt the window guides. Replace all the door gasket seals. Begin a quest to tighten every loose nut and bolt. Replace the Hardtop seal and tighten the bolts, replace any missing bolts. Lube the suspension.
Cruisers were actually fairly quiet when new, my first one was only a couple of years old when I got it. Not really hard to talk or listen to music in at city speeds. If they had Dynamat back then it would have helped, most of the noise not associated with age comes from the tranny and firewall.
Hope this helps.
Is it high jacking when I ask what undercoatings people have been happy with? I think I am going to ditch the Flow masters the PO put on too, probably the best place to start.
Most people doing a resto go with Linex or Durabak for the undercoat - you can also check out the cool tintable Sem undercoat buckroseau used in his 45lv buildup down in the 45 corner -
Tucker
I installed new pvc floor mats and the floor board insulation mat from CCOT. It helped with heat and sound a lot. That coupled with a new exhaust system fixed me right up. :cheers:
