Shaking fzj80
So awhile back I bought my own quasi prodject/driver 80 for 600 bucks. I finally got around to a tuneup over the weekend due to intense shaking on acceleration. I changed the spark plugs (6 wasn't firing) and the other 5 were white powder tipped. Seems it's running lean. Picture below.
Aftr changong the plugs it definitely ran better but still a lot of shake on acceleration and it's terribly slow. I find myself with my foot to the floor and just still chugging along. What do I go after next the fuel filter? Any help is greatly appreciated. I don't know the history of tge truck but it's pretty clean. (No check engine light)
Thank you for your help.
Did your tune up include a new cap, rotor and plug wires? You can ohm out your plug wires to verify that number six is good. Not sure what the ohm value should be, but I was guess they are all fairly close to the same. If one is open, that could be the problem.
What year? If it has obdii, maybe scan it anyway in case the CEL is burned out. After that I'd check for cracked or disconnected hoses, mainly the big air intake hose. I'd take the MAF off when you inspect the intake hose and spray it with MAF cleaner. Check the spark plug wires to make sure the insulation isn't cracking. Check the timing as well. Rule out the simple free stuff first.
I checked the wires their good did new cap and rotor also. It's a 94 so no ob2. The hoses all look real nice and new.
Maybe check your throttle position sensor? There's some pretty easy tests in the FSM if you have a multi-meter.
Well I'm pretty sure it's not the tps as I did the old school way to check it I yanked it and no change.(way too technical in the fsm for me)
ha, not really sure if that's a valid test of anything. You pulled the plug and revved it?
Anyway I thought of another common thing to check. Look at the engine wiring harness near the EGR valve. It frequently gets fried. It's known to cause problems with accelerating and shudder.
melted engine wire harness
Nope haven't seen anything like that. The reason I'm leaning toward the filter is I seem to be getting some sort of whine from around there. Thanx for your help. Does it sound possible that it is so clogged that the fuel is making noise just to get through? (About the tps sensor WOW!! did it look complicated to check it in the manual. so I did a quick search and it seems if the tps was bad it would run better if it was out because it would be getting a richer mixture)
I've never heard of that but I suppose it could happen. The fuel filter is a biatch to change. Certainly won't hurt.
I don't think you can see if your harness is damaged without removing the heat wrap, so it might still be melted even if it looks ok from the outside. That said, I don't know if the '94 even has an EGR system.
How did this problem start? Did it always do it since you bought it? Did it come on fast or slow?
It definitely came slow LOL!! Just not this slow the shaking kept getting worse until I changed the plugs then it got a bit better but it's still running funky. I knew it was reaaaaally slow when I got honked in the right lane 2day. I see how hard tge filter is to change which kinda reinforces my opinion that mayb it was never changed and maybe it's also why the car came with a spare fuel filter. It also came a few wires I have no idea where they go to I'll get pictures I the am. Thanx again for your help
Didn't have time to put it on today (yesterday) going to see if I have time today. (Everything is confusing at 12 am) will keep everyone posted if I get it done.
Don't forget to change out the fuel pump sock/strainer. An original strainer will cause low power "chugging".
Remove 2nd row seats. Pull forward the carpet. Remove inspection plate. Pull full pump assembly to change. Very easy, just takes a little time.
In order for your fuel filter to be clogged it must 1st clog the upstream fuel sock on the fuel pump.
Changing Replacing Fuel Sock Steps
Might be worth it to check the pressure at the fuel rail before going thru changing both filters.
Does Autozone "rent" the fuel pressure gauge?
I really should do that and loan it from autozone. But in my neighborhood I try and do anything to stay away from them. They are a pain to deal with and have no idea what you are talking about. I think I'll try changing the filter because it should be done anyways and if that doesn't do it I'll keep troubleshooting.
UPDATE:
so I changed the filter and from the little I drove it it seems to be running much better.
. Changing it was difficult but not terrible definitely worth doing it myself. Thanx so much for the help.
UPDATE:
After the filter it was running better but the symptoms started coming back. So I checked and through trial and error I checked through the wires etc all seemed good. So then I went after the injectors and voila #6 had no click. Before changing the injector I rented a noid light from pepboys and plugged it in( advance told me it was a thousand dollar light bulb that only mechanics have I'm telling you the quality of the folks who work in these auto parts stores..) so I checked and all seemed good ordered the injector spent about 3hrs wrenching (1st time attempting something so big) put in new injector and grommet and WOW!!!!!! she purrs and I finally understand the 80s hype.
