Shackle spigot
Unfortunately not. I need to spec either a 50mm or 51mm but nothing I can measure on the shackle I want to replace is either of these???
It's the inset thingy attached to the bolt part of the shackle pin/bolt. It's basically a 50mm or 51mm part that slides inside the side of the fixed end hanger. You have to undo and slide it out a bit to get a measurement. Or go with the 51mm and possibly clearance the hole on the hanger if required out to 51mm (if it's 50mm).
Look at the pics, the chunky part at the bottom is the spigot.
