Shackle reversal/SOA
Carthage, MO
For the last two weeks I have been researching whether to do a shackle reveral or not. I have read all the pros and cons, but still can't decide. The only reason I was doing it was for the approach angle and added wheelbase, but I don't want to worry about buyin a $ drive shaft. I am running a sm420/3 speed case and there isn't much room. I even researched doing a square receiver style shaft, but wasn't convinced about it fitting. I'm sure someone is running a square shaft with a 420? I am doing a cut and turn, so the binding of u-joints would not be an issue. I guess what I am asking is for some more advice on whether to do the shackle reversal or not. I would like that added wheel base, so I guess I could flip the spring around and adjust the military wrap to the proper end. I wasn't sure I wanted to create a weak link though. I want to do my spring over right the first time, but I don't want to go one way (shackle reversal) and regret not leaving the shackles up front. I already have the shackle hangers cut off and one of the fixed spring mounts, but they would be easy to bolt and weld back on without any issues? Any suggestions to help me decide. Thanks!
worry about buying a driveshaft? if going SO you'll need one anyway
Mark, I've (almost) decided to go with the FaultLine Fab SR setup, I'm hoping to have pics of the setup today (Wednesday) and I think it should work with the Saginaw conversion also. I'll be flipping the springs per Medusa's tech link.
I've never been a big fan of the spring-over, but allot of folks run'em that way. Just too much lift for me. I've got 4" springs and would like to get front end lowered about an inch and get my tube fenders built to clear the tires. The rear has sagged enough I can put stock length shackles on now and be okay. Just my .02's.
This would be the time to do it. It is not much more work. No question the traditional SR using the fixed hanger in the front and a tube through the frame will give you the best possible approach angle with leaf springs and this is a good reason to do it. If you think that flopping the shackle around is going to make it ride like a Cadillac and handle like a Porsche, you may be disappointed.
Pin_Head said:
..............If you think that flopping the shackle around is going to make it ride like a Cadillac and handle like a Porsche, you may be disappointed.
Maybe not. But you will get to experience what it's like to sit back in your seat and relax a bit. And no more death grip on the steering wheel. I bought my truck new and 2-lane Hwys scared the hell out of me from day 1 until the ride home after gettin my truck inspected after after my SR install. I had driven 10 mi. and found myself sitting back in the seat with 2 fingers through the wheel. That had never happened before.
Thanks guys! I am going ahead and doing it at the same time as the spring over. I have decided to run a receiver front shaft-seems easy enough to make! I wasn't really looking for it to be an improvement in driveability, just wanted a better approach angle and a longer wheel base! If it drives better, then I will take that benefit as well! :D Thanks again!
If you do a cut turn on the axle then you will have to run a CV joint unless you only go slow and don't worry about vibes while in 4hi. i think shackle reversal is a must, the handling is incredibly better and when coupled with a spring over and cut turn lets you set up all the caster associated parts at once to ensure you get the best of all worlds.
Cut the factory hangers off, a couple rivets and ten minutes with a cutoff wheel and then re-use them in front. If you don't run a cv joint, getting your stock d-lines re-tubed works but I know from my own experience you will need a much longer slip yoke or the shafts will come apart :doh: That may be easier and less work than making your own square shaft but probably a toss up.
CV is typicaly optional in a front application.
Not a bad idea mind you but with the SM420 it will be hard..
I had a rig that handled perfectly with a SO and no SR.
And I have driven horrible handling rigs with a SR (plus you will more likely than not need a long travel DS)
Most of the reasons for improper handling were related to worn bushings and sloppy steering (or poor front axle geometry) than wether the rig had a SR or not..
the ONLY reason to do it is for increased approach angle and to decrease the chance of bending a spring in a headlong impact...
