Shackle bushing help.
For the 4 decades that I have been wrenching on Cruisers and selling parts, I have come across literally HUNDREDS of deformed shackles that were FORCIBLY deformed during installation in order to get them to fit the springs and shackle hangers on the owner's truck. With dozens of companies manufacturing leaf springs that had slight [sometimes more than slight] differences in width, and dozens of bushing manufacturers making bushings with different thickness shoulders, manufacturers of fixed-gusset [the center piece] shackles simply made them wide enough to cover all the likely bases. Which meant in a number of cases they were simply too wide.
And that gap is not just a cosmetic issue. Any gap is going to affect the tracking of the front axle, as the spring can move side to side if the shackle can move side to side. So people just resorted to DEFORMING the shackles, bending them in until they reached the shoulders of the bushings. I must have tossed at least 40 of these that were qualifiers for the wall of shame.
Well when I bought a pair of these fixed gusset shackles for my FJ45 in 2008 and found that they were nowhere near being the right size, I decided to do something about it. I engineered a simple prototype for a test using some tubing and flat washers. Then after beating it around in the desert for 6 months, I dropped the coin on having some serious sleeves and plates made.
The side plates are 3/8", which is considered sturdy enough for the roughest applications I've seen anywhere. My center gusset is made from 1" round stock with a 1/2" hole drilled through it, making it .25" wall. Cut to the narrowest production-width spring/bushing combo, I include some extra flat washers to make the span cover the most likely combinations still being sold on the market. In 10 years of offering these, I have yet to hear from one customer who said they don't fit. And I have the satisfaction of offering the burliest center gusset on the market.
It is also worth noting that since a few companies still offer springs with a “military” wrap secondary loop at the spring eye, my shackles leave more room for the wrap. I have seen mismatched shackles and springs offered from the same vendor that literally bound up the spring against the gusset, which is like welding the axle to the frame.
As the shoulders of the bushings naturally wear down over time, I simply remove one of the washers alongside the gusset tube to bring the side plates in snug again. And if one of the side plates should happen to get slightly deformed [haven't seen it yet] I figure it's a simple matter to disassemble and invert the plate to draw it back.
So there you have it. The 1.5" longer shackles are 4.25" center to center. The 2.5" longer are 5.25 center to center.
Mark,
Thanks for posting up the pic and the description above! Looks like you've put together a good product. I know I have looked into your stuff before, but the other day when I clicked on the link in your bio and it took me to a picture I thought it was just another busted link, not realizing I was just one more click away from a glorious land of Cruiser goodies.
