Severe Misfire and PO306 code Question
This is what greeted me after driving to a store far away and then restarting the truck to head home. I had to creep home at 30 MPH.
So it's a misfire on #6 and I've often heard of things happening to 6 more-so than the others. Where should I start looking for the cause? I'm going to pull the ignition lead, plug and dizzy cap as soon as it cools down. Assuming that they're all ok, where else should I be looking? What makes an FZJ-80 miss on #6 most often?
How old are the plug wires? That would be my first guess as the culprit.
Wires, rotor, cap and plugs all went in 1-1/2 to 2 yrs ago.
Oh I forgot to mention that this same thing happened twice before in the last couple years. But only lasted a minute or so each time. And today as I was driving across the parking lot it cleared up, only to come back while on the road at the first traffic light. So it can flip like a switch, which makes me think it's pure electrical. No?
You WILL need to go through the various issues that have been identified over the years. My writeup in the link above documents the steps I took to narrow the issue down in my 80 and included checking harness near the EGR and re-wrapping as proactive maintenance all the way to finding #6 injector being dead.
Unlikely anyone here has a perfect crystal ball and can tell you what it 'most likely' is causing your problem. The obvious #6 specific misfire causes are harness near the EGR and same harness inside behind the glove box area, failed injector, blown head gasket :)
Time to get your hands dirty and start checking the stuff above.
cheers,
george.
wire harness coming out of the ecm under the dash on the passenger side. it rubs and shorts causing open injector on cylinder 6.
It's funny you say that because just a few weeks ago I ran two solar panel cables through the firewall on that side by snipping the two nipples on the rubber grommet below the wiper motor and pushing them through. Also ran a 1 AWG cable through the other pass through just to the right of that one. Do these sound like they run into those wires?
My former '97 80 series had 306 due to blown HG so as stated previously, check the items listed in a systematic method. Let's hope you don't have a blown HG and it's super easy enough to check. Look for bubbles in the overflow tank while someone is revving the engine and pull out the #6 spark plug to see if it's been "steam cleaned".
I knew this was gonna happen... I just went to pull the truck into the driveway and it's running fine again.
The only thing I can say is that it was hot before and now cooled off.
EDIT:
It's missing again.
Pics of #6
I've never actually seen a steam cleaned plug before but this looks pretty typical to me.
Switched plug wire for the old one that was still good and no luck. Was about to pull the dizzy cap but got rained out.
I pulled the glove box to check the wires mentioned above but couldn't see wiring that was recognizable. Didn't know it was so tightly packed in there. There's no way to see where those two looms enter the passenger compartment, but I think I could see and reach the larger one from the EGR, it had a lime green label on it..? I could not see anywhere it could be rubbing sharp metal.
Thanks.
I couldn't see much over there because of the stereo amp. Do you not have yours anymore, or did you maybe pull it for this misfire problem?
I saw only one box with a mega wire plug on top right in front, but I suppose that's not the ECM...?
I'm gonna have to go look up the "anatomy" of an FJ80.
EDIT:
I found the pic below, it's from a 93 FJ80 though. Is this the same location as a FZJ '97?
What about the rest of the gadgets? I'm trying to at least learn something from this 306 situation, get a better working knowledge of my vehicle.
img_5882-jpg.437259
Your plug looks typical so that's a relief. If you're able to repeat this issue, perhaps stick a timing light on the spark plug wire and see if it's sparking consistently. Have someone behind the wheel and power brake while you're under the hood with the timing light. The engine needs to be under load for this issue to reoccur I'm guessing.
If the spark is firing ok, then you're left with the injector not firing properly. Not sure what kind of gadget you can use to check the firing of the injector in our rigs, someone with more experience can chime in on that. They run a high duty cycle so using a typical multi meter won't work, you'll need an oscope for that. Wonder if any of the OBD-II software is capable of reading the spark and show it on a graph of some sort?
The other thing you can try is to swap #6 injector with say, #1 and see if the CEL code follows it. If so, that's your issue.. This is a huge PITA though!
Check out the pics of the ECU harness going by the EGR that often gets over heated and some insulation melts as a result. See if yours look just as nice and not cooked or melted. George's link from above Injector Service
This will be a tedious process but you'll learn patience and proper troubleshooting which will serve you for years to come. At the end, it's usually something trivial and it's a quick fix but the process to find it can be arduous. Try not to throw parts at it!
Thanks Alia176, yeah swapping injectors is a bit out of my league. Maybe in the future.
I read about scoping injectors, but unfortunately... maybe in the future. LOL
Since I'm not using the truck today I dropped it off at the shop last night. Got a message back earlier that the injector is believed to be shorted internally. I told him about the ECU issue when I brought it and I just hope he kept that in mind rather than assuming a non firing injector is simply the injector. He can be a bit of a part swapper as opposed to a crack diagnostician.
I'm still researching and reading up on all you guys have given me. And thanks again for that!
I keep thinking about the solar and rear power cables I ran through the pass side firewall and down the kick panel just a few weeks ago. I hope that didn't cause stress to those ECU wires.
The thermal insulation on the EGR area loom looked so pristine that I didn't want to take it off just yet. I tried going behind the glove box first, considering the new cabling I added there.
I read up a little about shorted injectors and I'll report back when I have news.
Well folks, nothing special or exiting to report, it was indeed just the lowly injector that had gone bad internally.
My only remaining question is the price. The heater valve was falling apart also, which I knew about and was going to do myself but he didn't know that and changed that also. Total bill? $440+tax. If you have to remove the upper manifold then I can see the cost. If #6 injector can be changed without that step then I have to take issue with an almost 3 hour labor charge.
Removing the injector requires removing the fuel rail. To remove that is a pain since the 'easy' way is to remove the upper intake manifold and still a bunch of work.
I'd say 3 hours to swap out an injector is quite reasonable if you factor in the entire job from opening the hood to closing it. Remember the also diagnosed the fault.
There's a reason most of us work on our own vehicles, 1) save a bunch of $$, 2) do the job properly, 3) be at one with the skinned knuckles, grease, oil etc
Did you ever read my thread (linked above) on fault finding/replacing #6 dead injector on my 80?? Do you think you could do that in 3 hours?
cheers,
george.
That's what I thought but needed to confirm. Thanks George.
I couldn't do it in three weeks.
Yes I did read your linked adventure and also saved it for the future.
I WISH I could do all of the work myself. If it weren't for health issues/injuries I would be in it every day replacing repairing or adding something.
Unfortunately, pain is my constant companion.
I kind of regret not telling the mechanic to replace all injectors while it was apart.
Glad the issue has been resolved. Now, go get some wheeling done!
