Several problems Need some suggestions
Savannah, GA Area
ok, the newly acquired 73 fj-40 has been giving some trouble that past few days.
first off, every time a drive say 30 minutes or more. and cut off the engine, and then try to start up it won't. i have to wait for about 15 -20 min. starter does seem a little sluggish. but. i don't know. it's not sluggish enough to fire the engine i would think?
second thing. just yesterday started smoking ALOT. at idle., at driving. and easing up on gas. i have no oil leaks underneath after sitting over night. any suggestions on what to check out first? rings? valve seals?
that's the bulk of the trouble now. any help is appreciated.
is the smoke oily or is it just white and puffy? if its just puffy and white it could be a head gasket!
Checkie your compression. Dry and wet.
Start w/ the basics, check the plugs for fouling (oil/carbon) If oil, could be bad rings or a valve stem seal.. A compression test could help, but if the car is running fine and only hot starts are a problem it could be other things (fuel, timing, starter, or coil). Does it idle high? Might check for vacuum leaks as well.
Mike
i will be getting a compression check this week. before i order parts i don't need.
about the vapor lock issue. could it be a stuck heater flap?
if it would only cool down for once in south GA.
thanks y'all for all the advice
so i put in new valve seals and i've still got smoke. then i did a compression check with a cheap auto parts store checker. and #2 cylinder is at about 50 psi. the rest are around 130-140. this was a dry check. also the #2 spark plug was very fouled up. carbon and soot. so i clean it . then take her for a ride and pull it again and it's wet.?? so any help is appreciated.
the neighbor calls me the skeeter man. i have so much smoke coming out the exhaust. its funny, but it's NOT
rcb said:
well, i'm more than likely going to replace all the rings and bearings while i'm at it. would it be better to pull the engine or just drop the oil pan and take off the head on the cruiser?
Depending on mileage, results may vary! Unless the engine is pretty low mileage, the ridge on the top of the cylinder bore will be significant enough to potentially damage pistons and rings upon removal.
