Set up guages
Lynchburg, Va
I am looking for information on how to set up my guages but have been failing with the search function. Any direction would be much appreciated. I have a '71 FJ40 that has a Chevy 305 put in by a PO. None of my guages work currently and I need to figure out how to get them set-up. Thanks!
Do you only have the OEM cluster gauges or do you have gauges that will work with chevy temp sender and oil pressure sender. I still using OEM the AMP and fuel readouts should work with stock wiring and OEM fuel sender. Someone on mud makes a conversion cluster for round autometer gauges.
1. There are LOTS of threads on aftermarket gauges.
2. To make the stock ones work, all you need are stock sending units, adapters to go from the metric to SAE fittings on your engine block, and some wire to extend the leads.
3. That said, given the fact that the factory gauges are one step avoiding lights, and easily susceptible to shorts, you should post up a pic of your cluster so someone can tell you if your gauges are even going to register once you go through the work.
Hint: if the gauges are off the scale when at rest, they’ve already been shorted.
Best
Mark
www.marksoffroad.net.
