Graduation on AHC reservoir, help detriment health of globes. But can be misleading!
It's been said that, a new AHC system will raise hydraulic fluid level 14 graduation marks, from "H" to "L" in the reservoir. That 7 or lower indicates the system accumulator globes are shot.
After flushing and minor torsion bar adjustments, to get just a small ~5/16 drop in front end (rake).
Optimal 3/4" rake. I see axle to fender measurements and mpa pressures in tech stream of:
---------LH--------RH --------mpa
Front 19 1/4,-----19 1/4-------8.1
Rear 19 11/16---19 11/16-----7.1
Optimal pressures are front 6.9 mpa and rear 5.6 mpa.
I noted only 8 graduation from "H" to "L" at this time. Not good, but subsequently improved with adjustments of height sensors!
So I had my work cut out for me. This would be more than tweaking torsion bar tension.
I decide to start by dropping rear as far as I could. To this end, I dropped the sensor arm to low point in control arm bracket slide. Moving the sensor down by ~16mm (lengthening arm). This gave me a rear pressure of ~5.9 mpa without driving to settle.
Front went up to 8.9 mpa. Note: I only had ~1/2 tank of gas. So I added ~50lb to very rear LH cargo area. This would help me simulate closer to full tank (under 2nd row LH seat) of gas.
Next I moved to the front to drop it. The adjusters nut in both sides slid brackets were at bottom, giving the longest length (lower vehicle front). So I extended the turnbuckles ~12mm from LH 34.5mm to 45.85mm (inner measurement) RH from 33.00mm to 46.33mm.
I measured axle to fenders again and pressures (without driving to settle).
--------LH---------RH-----------mpa
Front 18 3/8, 18 5/8
Rear 18 15/16 18 15/16
Than gave torsion bar
------1 CW----------1/2CW
-------LH--------- -RH--------mpa
Front 18 7/16,------18 1/2
Rear 18 15/16------18 15/16
Than raise rear by moving adjuster up the side by 3mm
----------LH--------RH-----------mpa
Front 18 3/8",------18 7/16"-------7.7
Rear 19 1/16",-----19" ------------6.4
The graduation from "H" to "L" now improved to 10. Now that is interesting
So now I've ~5/8 rake to aid in reducing HWY wondering. I'd like a little more with the K02's, but good enough to take in to Toyota Dealership and have alignment job done.
The pressure are better but still high. I'll recheck and tweak soon. But will have to do, for now. .
Future recommendations:
I feel it needs new rear OEM coil springs and 30mm spacers. This would bring rear pressure down to perhaps 5.9 mpa or may be less and raise rear ~1".
The pressure are better but still to much weight on AHC system. By raise rear, the front could then be raised by tweaking AHC sensor adjusters and CW cranks on torsion bar. This would reduce front & rear AHC pressure and more rake could be added.
The result would be longer life of globes, more "feel" and affect when adjusting confront control and better ride feel.
