Service History question
Colorado
I am not sure this is the correct place to ask, so let me know if not.
I recently bought my 80. The PO didn't have any records on it. I pulled a Carfax and the first owner (I'm the third owner) appears to have had a lot of service done to it. Carfax lists a lot of stuff like this:
01/29/2005
64,023
Service Facility
Maintenance inspection completed
60,000 mile service performed
Engine checked
Engine serviced
Differential checked
Transmission checked
Transaxle checked
Transmission serviced
Differential serviced
Transfer case serviced
A lot of times, Carfax will list exactly the shop that put the entry in, but in this case, it's just "Service Facility"
My question is, does anyone know how to find out where this thing was serviced? I went to the Toyota owners site and punched in the VIN, but only one record came up.
Thanks in advance.
Like most of us, you'll just need to baseline it, probably.
Even if it were regularly serviced, there is a good chance a non-LC 80 mechanic did the work.
Yeah, I am in the process of just starting from a black box. Rear axle has been gone over already, working on the front, PHH, etc.
I would just like to have them for future use in selling it or whatnot.
All dealership service means is someone paid a lot for service. Dealership have been known to hire morons also. The quality of work is only as good as the guy with the wrench. Verify and check everything if you want to be comfortable.
M
Most Toyota dealers can run the VIN and print out service records, IF service was at a dealership. Your 2nd owner probably created a gap on service, so start base lining and get it up to speed. John
