Serious performance boost!
I know for many of the regulars this is old news, but I am sharing it for those like me who might not have realized what an immensely dramatic increase in performance swapping out all the old vacuum lines, valves and ECG gear makes.
What got me into this was a check engine light. It inspired me to invest the roughly $500 all these parts added up to because I’m trying to get her perfectly prepared for the next 20 years.
What I didn’t realize was what an extraordinary difference it would make to the performance. It feels like I’ve gone from a tractor to a sports car! The difference in pick up off tick over and the torque up hills is extraordinary, it’s a total transformation!
Here’s a couple of pages screenshoted from the manual so you can see what I swapped out.
What other than hoses did you change?!
You replaced everything in that diagram?
All the tubes, since they’re 24 years old, the EGR modulator, EGR valve and the VCV for evap. I got the tubing by the yard and cut it to size, and used some sealing grease to bond it all
Did you have to adjust the transmission kickdown cable after the work? If so that may be contributing as well to the peppier feel.
suspicious or skeptical?
Didn't touch the kick down, didn't even know about it.
Not sure what there is to be suspicious about. Do you think I'm part of some odd conspiracy that's trying to get people to buy car parts, or are you calling me liar?
My comment was to @nukegoat about being suspiscous and seeing if he meant skeptical :). Just trying to give him a hard time. I asked about the kick down cable because it can change the shifting and give a peppier feel. Back when I changed the vacuum hoses I had the intake manifold off so it had to be re-adjusted when buttoning it back up which is why I asked. I am not going to call you a liar :) I am all for people maintaining these vehicles and glad it made such a big difference in performance. I changed out all the same stuff and had the injectors cleaned back when chasing a p0401 and don't recall a major change in performance. Maybe something you changed out was plugged up and that made the difference? Nice job on the work and for posting. It does feel good to replace 20 year old rubber with new.
I appreciate your pedantry. But I start with suspicion
Could be, the tubes were all pretty loose and also very hard too. Everything removed showed its age and effects of the engines heat over 24 years.
Not really sure what the it all does or why it would/could make such a difference. I'd have thought a CEL would be triggered long before it would/could degrade and affect the performance so much, but my story is my story, and I have no need to report anything but what I experienced.
What he is saying is that HE is suspicious. We'd all agree that he is very suspicious. Especially at night.
I went wheeling today
Did you replace the PCV, breather, and air intake hoses all
at the same time, and were the old hoses cracked?
Yes, I swapped out the air intake (new one from Wits End) and it was indeed cracked through on the inner most rib/dip.
I didn't do the PCV & breather - that hadn't come up anywhere as something to swap out?
...Grasshopper...
