Sensor identification ?
North Carolina
While removing this oil filter I broke 2 sensors near the oil filter I was able to identify the first sensor as the cooling temp sensor.
Knock sensor?
Note that there are two (maybe three, depending on how you define them) coolant temp sensors.
The one in the front blue circle is the gauge sender.. single wire. NOT the 2-wire sensor that sends a signal to the ECU for fuel injection control.
Thanks for reply
Ok so it controls the temp gauge? I'm going to do some investigating. Very hard to see what I have done because of the intake manifold . Also the 2nd one in blue on the right is the knock sensor? It appears as if I have screwed up both ends of the plastic connection pieces some how... will try to get a picture.
Yes the slightly lower blue circle is the front knock sensor. If you look at that pic above there is another identical sensor between cylinders 5 & 6.
To complete the ID.. the small round sensor partly covered by the red circle is the coolant temp switch.. this shuts off the AC compressor if the water temps get too high. The one in the circle is the 2-wire ECT engine coolant temp sensor for ECU control. The one further back that is black in color is a vacuum temperature switch.
The real question is how the hell did you smack that one and not the temp one
That is a great quest
I appreciate you taking the time to identify the other sensors. I'm not sure how I'm going to fix the temp gauge one because it broke at both made and female end. I was going to buy an aftermarket anyway. But the knock sensor. Will I notice a major difference until I get it fixed? I read somewhere it can cause trouble.
I was trying to hurry along and I should have looked better before trying to man handle that filter. My old filter removal tool is the type with the band that contracts as you rotate and the handle and my hand just knocked whatever in its path apart. Not sure how the other sensors survived..
I have learned from this mistake and I am going to slowwwwwwww down from now on when I see any sort of wife obstruction. Made me sick to hear the crunch of plastic :( -$
