Semi real time help: steering stabilizer
NaterGator
On Gilligan's Island
Gainesville, FL
Well, got the OME 2.5" lift done today. It was easy peasy, took about 3 hours all said and done... only ran into two problems. One was my "help" snapped one of the bolts for the swaybar bracket when re-installing (grr! :mad:)
The other is the gosh durned steering stabilizer.
I have read the threads to know that it is a pain and causes alot of greif, but I spent a solid 4 hours trying to get that darn thing off and I had no luck.
After I searched I used heat, an impact hammer, various pullers, various crow/pry bars... I tried everything I could think of. I didn't even get a thread's worth of movement I dont think.
The worst thing is that I cannot rethread the old nut on anymore. I had to drive it 120 miles back to gainesville because of school, and I wasn't that worried (considering I couldn't get the damn thing out try though I might) but I really need to get the old one off now.
Is there a special tool I should be using that will make this a snap? I saw Dan mention something he had, but IDK if thats an option for me. Perhaps I would be better off taking this to a tire shop, stealership, or whatever and letting them do it? Or maybe there is a cruiserhead in the North or Central Florida area who has experience with this and wouldn't mind showing me how it's done? (I would compensate you, of course)
Help! I need tips. I would love to take care of this asap... I know that thing isn't going anywhere right now, but the rubber is off the joint and that grease isn't going to last forever.
(Oh, and the OME lift kicks ass! :D)
-----Nate
Ball joint "fork" will take it right off
Ruheaaaaaally?
When you say "right off" do you mean I can definitely get it off with a ball joint fork?
I damn near bent a crowbar today trying to wedge it off... I hammered and wedged and pryed everything I could think of to try and unstick it...
So a decent ball joing "fork" and a BFH will be up to snuff? I'm willing to give it a shot...
You have an impact hammer.......did you use the impact hammer picklefork attachment?
I no longer have access to the impact hammer, but I did not have a pickle fork attachment. I did have a few various attachments though and came at it from various angles, with and without heat.
I am just worried that I was already applying so much force and prying so hard that I was afraid to go any further lest I damage some steering component...
I had no pickle forks on hand though, and I'm willing to give that a try.
Ruheaaaaaally?
When I did mine a few months ago, it took about 3-6 whacks with a 2Lb. hammer.
Alright, well I'll have a go this Saturday with that approach. I don't know where you find room to hammer though... I crank my wheels all the way to the left and there's still little room to work up a good bang :cool:
Thanks for the help, I am so sore and beat up and tired of trying to get that f*$#ing stabilizer off that I can devote no more thought to it tonight. I feel like a dolt for even trying, because I doubt that it will be that different from the stock stabilizer.
Man, and I still have to do caster correction too... the steering definitely feels too direct and 'darty' :doh:
Thanks again for the advice :cheers:
Man, I suck... I didn't even give you guys before and after pics!
Before:
After:
Thanks for all the advice.... will update sometime on saturday after I've had another whack at this (bad pun intended)
Just did my last week, a real PITA. Pickle fork+2lb. sledge and don't take no for an answer! Trust me, I was about to give up and burn the whole thing for insurence money and the bastard came off.
Good Luck
struggled with mine and TREs a bit and finally used the correct tool (screw on vise thingy described in an earlier post) and they came right off. Don't use a pickle fork IMO.
Pretty sure its the same as the toyota tool
informationjunky, what is the size of that tool in my hand? It looks like if it were small the pressing arm would create such a tight arc that it would actually bend the bold rather than press it out?
At this point I'm thinking of going to sears real quick and buying a pitman puller and pickle fork, and alternating using the two (together if possible) to try and get this thing out...
Dude,
This tool is the best! Do not waste more time and money on pickel forks and BFH!
This tool will work every time without damage to greese boots etc.
And it's on sale. Recomended by Slee!
This is what I used after having a similar experience like yours and yes I drove it a week without a nut;p
http://www.thetoolwarehouse.net/shop/OTC-7315A.html
Dude,
that's the one I was talking about.
Plus you can get it cheap at your local NAPA...
it's beefier than it looks, feels very solid. There is one even beefier that NAPA carries too. More $$ but quite a bit bigger. May be in issue in some cases.
You need the small pickle fork that Napa carries. I can't remember I think it cost @ 20 ducats or so. A couple slaps with a 2# mallet and your done.
It is about 5" long, very beefy. Mine came in black instead of the chrome shown. Hint its the same priciple as http://www.thetoolwarehouse.net/shop/OTC-7315A.html
but you have the added force of a moment arm.
They even have it cheaper http://www.thetoolwarehouse.net/shop/TA-61900.html
