haven't looked at one in a while, but is there room to slip a small left handed drill bit in there ?
if so, you could try to lever it in with a bar ( dimple the bar with a slightly larger drill bit, so the l/h drill bit stays put) to put lots of pressure on bit, then turn bit with a pair of vicegrips until it bites and starts to cut. at some point during this the cutting should make the bolt back out...if you're lucky.
