When I purchased the cruiser a few months ago, it did not come with a key fob. The person I purchased it from had no idea if/how the security switch worked. It has never gone off but there is at least some power to it because the LED does light up. My question is, does this do anything? And if I disconnect the battery, what should I expect when it gets reconnected? Do I need to do anything to get it back to not doing anything?
I have the same question, same issue, however I pulled the console and found a fob under there. I have not put a new battery in it, and have no idea what will happen if I do, and give it a try. If I leave my truck for 2-3 weeks without starting the battery is dead or low, and the only thing I see that might be a drain is that light and its associated parts.
I've got the same. Can be a little of a pain after battery is disconnected/reconnected, and can go off after a few minutes (horn alarm goes off).
After reconnecting the battery, you want to get the "valet" setting back on. With key powered to on, press and hold down the "valet Mode" side of the switch until the solid red light comes on. Turn off key. Then when you close the doors and lock them, the red light should flash constantly, showing armed.
In that setting, you won't have to worry about the random horn going off, and it is secure from break-ins.
