OK before I get flamed for not buying an OEM or Koyo radiator let me explain my situation for getting the NAPA radiator in the first place. About 3 ½ years ago, as preventative maintenance, I replaced the major components of my cooling system with OEM parts including a 94’ brass radiator, water pump, thermostat etc. and have religiously flushed the system at least once per year and replaced the thermostat.
Fast forward 38,000 miles to Dec. 2010 when I find that my OEM brass radiator is leaking out of the bottom seam where it meets the plastic. My original radiator had lasted 180,000 miles so to say I was disappointed is an understatement. To top it off I was heading out to Anza Borrego in two days to camp and wheel and needed a radiator fast if I wanted to make the trip. I had read good things about the NAPA radiators and they offered a lifetime warranty so I thought I would give them a try since they had one I could pick up the same day. At the same time I replace the radiator cap with a cap from NAPA.
Fast forward 5,000 miles to April 2011 when I am on my way to work and at a stop light steam starts pouring from underneath the hood. I pop the hood to make sure I am not on fire and see that the top of the radiator at the seam is spraying coolant all over the engine. After a couple well placed cursed words at plastic topped radiators in general I limp my way to work and then get towed home where I remove the radiator and take it back to NAPA for a warranty replacement. NAPA replaced the radiator with no questions asked and this time I got a new OEM radiator cap from Toyota.
My question is could a radiator cap cause a radiator to fail like this if it were faulty and why can’t someone make an all metal radiator that doesn’t cost $840? I know that it could have just been a bad radiator but when I compared the caps there was a noticeable difference in the springs.
