secerity system removal ???
I have a 1995.5 fzj w/obdII which i am in the process of removing all of the carpet on the inside. Under the drivers seat there is a black box which has something to do with a security system which is currently switched off. The box is a toyota part.
Can i remove this box ie cut and remove the wires??
Peyton
Removal of the port installed security system on my 97 was pretty straight forward. Just follow the wiring loom from under the seat to under the dash. There will be several connectors to unplug and a couple of wiring T's to remove. You *shouldn't* need to cut any wiring, but you may end up having to fix a wire or 2 from those crimp down wire splices.
I would be interested in the uncut loom and box.
When you follow that alarm harness to the chassis, you may have to reconnect some connectors on the chassis harness, that may have been used as a starter interrupt circuit. I had to do that on my 96 LX (details in the link in my sig). You can test it by unplugging the alarm module and then attempting to start the truck, if it won't start at that point,you will know you need to make sure that a circuit, used as a starter interupt, on the chassis harness is reconnected.
Probably a stupid question on my part, but does removing the security system remove the remote locks? I'm guessing yes. I like the remote locks, but would like to pull the security system. One more thing to break...
Yup, the remote locks will no longer work with the factory system removed.
And I think the starter relay circuit wiring is all handled by the couple of connectors at the ignition switch IIRC. When you remove that part of the harness, and plug the ignition switch back into the factory harness, you should be able to bypass the relay wiring.
When I had removed mine, I found out a PO or shop had misdiagnosed a blown fusable link, and had soldered in some goofy jumpers in that ignition switch harness from the alarm to provide 12V to the ignition system. Took me a while to figure out WTF was going on, but once I tracked down the blown link, the alarm came out easily.
i haven't tried to figure what causes the chirping noise, but if you remove your security system and no longer need it, I'd be interested in buying whatever creates the chirping noise from you. Mine is inconsistant. It seems to only work when it wants to.
there is a piezo chirper under the hood, near the master cylinder. it is wrapped in a piece of gray foam.
it is common for these to fail over time. some mudders have gone to radio shack and picked up a piezo chirper and wired it in place of the OE unit.
do a seach here. the OE unit is also sourcable through state side distributors.
Do the radioshack ones sound similar to the oe' ones?
I know I have my alarm module still, and I think I have the OE chirper kicking around. I'll have a look and see if I can find it. The harness I want to keep for splicing in a nice aftermarket unit.
So i received my oe piezo from the local dealer today and it comes with a 10 feet wire. I may be exagerating but it is very long. I thought that the oe piezos from Toyota was a plug and play deal. Looks like I may have to cut and soder the wires some how. Or is the wire long because I'm supposed to run them back to the alarm brain? Has anyone experienced this with their dealer bought piezo chirper?
Please feel free to chime in what you think.
The piezo wire (and I'm doing this from memory) was just a bare wire through the firewall, which then was spliced into the the proper wire going back to the head unit. I know my harness was in 2 pieces. the piezo chirper/wire and everything else.
I would just cut the wires at the old piezo, twist the wires from the new piezo to the original wires to test, then if it works just splice it right there, using some crimp connectors. If it doesn't work when you test it, then there is probably a problem with the wiring, so I would fish the new wire through the firewall and connect it directly to the alarm or close to it.
