Seat gear install help
Some people use a vise, I tapped the gear onto the splined shaft using a socket and hammer using a piece of wood as work surface.
I used heat and a socket. I recommend applying the heat gun to the metal shaft, which will heat the innermost portion of the plastic gear, as you slowly apply compression with the vice. The plastic will soften and the gear will seat, then back off.
I wrapped making the around the shaft to create a "bushing" to keep it centered then pushed it on with a socket and table vice.
I wrapped MASKING TAPE around the shaft to create a "bushing" to keep it centered then pushed it on with a socket and table vice.
