Build Search and Rescue JoKe (2014 JK)
back is done
Quickdraw sent a 100" belt, this is 102 1/4" belt and too short. Going 1" larger.... downside is those green belts are $100 each
so will probably get another 'cheap' belt to verify length
Now with lift
2 1/2 lift.... lol.... I wonder if the guys who put that marketing on the lift kit did the "yep, looks like 2""
conversely, the back is 2 1/4" lift
Fittings
Fitted
as is typical, one fitting is missing (mind you, I bought a bunch as backstock for my hydro assist stuff on my other 4x4s
fun fact - the take-off for the vacuum is on the front of the 3.6, it's also on the front of the r2.8....
this was not fun to run at the firewall... but the heater is done
and when removing the gas tank, also test the tinsel strength of the pump wires
video shortly
a bite at a time
the adapter to the PS pump
and connected
and then the almost right belt.... I ordered the one size smaller - this will work but it will lose tension the moment it starts stretching
installed
thinking this is where the filter will go....
and classic, it works
but lost one bolt
it should work (stock radiator)
new panhard bar, just waiting for install
time to make a hole
for this
haven't decided where the motor's battery is going to reside. Probably behind the passenger seat... anyway besides moving stuff around - this was my 'major' accomplishment tonight
Went to Portland to visit dad so didn't get a lot done... however
installed the new, adjustable panhard
and new stabilizer
then spent quality time seeing what it would take to make this fit
this is now redundant
Cummins makes a shorter oil filter... less fittings, sure less cleaning (but there is a work around with a Franz style filter)... that said this is a every 3k oil change so I'm not as worried
then got to work on the tank.... ordered the fittings and hose, should be here Tuesday
Thankfully, with all my spare time, an old guy had a medical emergency and nearly head-on ran into me. Hoping he has insurance... glad he's not dead, it was touch and go there... it's odd to go from victim to rescuer in less time then it takes to type this....
Oh yeah, all while on my way to church (he was headed the wrong way ;) )
back to Jeep content
I've had the 'other' window since Woodinville - so giving it 2 years to age seemed like a good idea. That and I'm waiting on parts so time to get other stuff done
and the insert
and the window removed
removal tool
a bit of windshield glue and it's in place
back to diesel content tomorrow
back to it.
$200 later and the right belt
one that works (neither of which came from Quickdraw) but note how very little space there is between white marks? that white mark is where the tensioner is when no belt is on
this is the correct belt installed - note the white mark on the tensioner?
now that's sorted... time for my nightmare
Fittings arrived
didn't buy enough hose but napa carries it so it'll be fine
disabled the electric pump - found nice metal bits in the well
removed the one way valve in the assembly to disable the pump. It's still in there in case I ever LS this or need it but now it's most certainly off
this is impossible for Jeep dealership mechanics.... snapping the fittings together - no maybe y'all see why I'm so irritated at them. Even engineers could fix stupid
need to get a 5/8 overflow hose
get the tank in, then realize I can't get it all the way in because the lift is in the way
last line for the fuel tank
now run to the filter then to the motor
and got the short filters in
compare then installed
intercooler came today
left to do:
radiator
intercooler
wiring
time to fill it up....
also put 10 gallons of diesel in it... pickup works fine
and cooling
of course the hardest thing is to remember how this puzzle goes together.
after a bit of research, it all went back together then the intercooler
I got a 'deal' on this (meaning only about twice what the parts would cost alone) but this is for a JK with a supercharger - so some connections required
but it all, basically, bolts in place
you'd think I'd have tubing to connect this.... but no so I wait
we'll get back to this and in the meantime build coolant tubes and get onto wiring
onward with the plumbing
need to reduce twice to get to the radiator size
now polished
and assembled
and bottom one
and this is lurking
actually, outside of one bracket, it shouldn't be terrible - just clip what I don't need
first step, install the radiator tubes
downside is I need to weld another bung on the upper tube for the bypass
intercooler plumbing
and waiting again because I don't have a length of 2 1/2" pipe (tomorrow, I hope)
still have the left side tube to do but hopefully tomorrow that will be solved
it's really time to start figuring out where the computer will go
the plan is use the old computer for sensor, speedo, and HVAC control duties. If I can figure out the cruise control that too.
I still have no idea what the airbox is going to look like.. the hole to fill
2" inlet, 3" MAF sensor tube - thankfully someone makes a 2" to 3" 90 degree elbow.... just take a week to get
the box sent by Quickdraw
fun fact, the cap costs $80 to replace
or
just steal it off the old Jeep motor - it fits just fine
Instead of useless air intakes, Quickdraw should have made a bracket to adapt the throttle pedal....
also substantially bigger - and the hole ain't great
for added thrills the angle isn't the same either....
ah well.
built a bracket
painted it
then test fitted it, twice, now it's basically in place
need to do a bit of fine tuning but it took heating and bending to put the pedal where the old pedal was
my most favoritest thing EVER! ... or not
about the only spot to send the harness through the wall is here...
as I said, not optimal
but drilled through, then spent some quality time trying to thread the connector together.... haven't won yet.... not happy.
this also shows where the computer is going to live....
I might start getting up early, work until 10 then do my office job until late during this little warming thing.
