143 Thousand Miles, 1cv axle, 2sets of front wheel bearings, one rear wheel bearing, replaced LCA's, soon to be replaced front windshield, a few idler pullies and Zero Regret! Just honk the horn before backing up!
So this is the current set up:
2008 Sandstorm with about 143k
Front Suspension:
- Bilstein 5100's with toytec/Elbach 3"lift lift springs
- Currently on free floating sway bar links.. soon All-Pro solid sway bar links
- Camburg Ball Joint UCA's
Rear Suspension:
- Bilstein 5160's
- Super Flex 2" lift springs
- Sway bar disconnect Links (currently disconnected)
- Extended Brake lines
- MetalTech adjustable lower links
- OEM upper links
Brakes:
- EBC 3GD Rotors front and back
- EBC green stuff 7000 series front
- EBC green stuff 6000 series rear
Armor:
- bent, scrapped and abused front/transmission/transfer case RCI metal skid plates
- Boztec rear diff skid
- dented and scrapped OEM rock sliders
Bumper and winch:
- Trailworx tubed winch bumper
- Smittybilt XRC 9.5 synthetic
Intake:
- PRG Snorkel
Drive train:
- Raised Rear diff and locker breather (still need to do the transfer case)
Lighting:
- 50" KC Gravity Pro6 LED light bar roofrack front
- Mictuning /
Amazon LED, 2x 18in(roof rack left and right), 22in curved(hood)
- 30in
Amazon no name brand(roof rack rear)
- 6x Free
Amazon cube lights for temporary rock lights
- 2x Disconnected PRG 8.75in diameter LED lights on bumper
Electrical:
- Switch Pros SP8100 8-Switch Panel Power System (Super easy, painless wiring system and highly recommend)
Wheels:
- FJ80 16x8 wheels painted in what I call "Root Beer flake"
- Synergy 1.5in spacers
Tires:
- 285/75/16 DickCepek Extreme Country
Roof Rack:
- Soon to be delivered Warrior Platform rack
Visual
- Trailworx Hooped light bar mount
- Bushwhacker fender flares
Other:
- DIY rear door food prep table
- EdgeStar 43qt refrigerator
- DIY 3in tall rear Platform to level the back when seats are lowered and E-tracks tie down brackets
- The Source 10lb CO2 tank with regulator
- Cheap skull shift knob from Walmart
- Cobra 75w CB w/ 3ft Firestik 2 antenna
- indoor/outdoor wireless thermostat for frig temp monitoring
- As Screen on TV pocket fisherman fishing pole and telescoping pole
- Removeable Office carpet under floor (flooded the inside and had to rip out the soaked oem insulation)
- more to come!
