tearing his hair out borrowed mine. Two minutes later discovered a bad cable. Well, it looked fine. :whoops:
About tunning antenna ..saw YouTube Vid explaining you should do that in open space .. the Guy I'm the Vid was in the middle of nowhere .. question is how much space you need for proper tune?
I even experimented on my own trucks, and there wasn't any difference between inside my metal shop building and out in the middle of the pasture. Just my personal experience; YMMV.
thanks .. coz I'm planning try on this one ..
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Where are you going to mount it? That's a 1/4-wave antenna so it will require a good ground plane, like your roof or hood.
You are close enough and have enough antenna above the hood that you may get enough ground plane for a 1/4-wave there, but be sure to check it with an SWR meter before transmitting.
I used the YouTube video and Internet info to tune my radio/antenna and I have a question.
After adjusting the 3' firestik antenna, I replaced the weather cap each time. I had a hell of a time achieving the lower level on the SWR meter. Then I just left the weather cap off and I was successful in dialing in the SWR, 1.5 on both CH 1 and CH 40. Putting the cap back on the SWR went up to 4.6 to 7.5 with no other adjustments.
What the heck????![]()
