I've been searching but can't seem to find any specific threads on this topic. If anyone knows of some good informative threads please post up.
Basically I know very little about the MC toybox other than:
-it uses a minitruck gearbox and adapter
-you have to replace your transmission tailshaft (I've found several writeups on how to do that)
-you have to modify or forgo reverse lights
Questions:
What are Iron Pig specific issues dealing with the toybox install?
-Are these even available for a stock drivetrain? Will they ever be again? (I only see 5 speed or SM applications on their site, though it is all under construction)
-Do you have to cut any holes in the floor if installed in a stock drivetrain? {EDIT: Looking at the picture, I see you obviously do, so next question is how far back from the gear shifter does the hole have to be?}
-How much does it change your driveshaft lengths?
-Is a stock transfer case able to realistically hold up to the torque?
-Any other install issues like fitment under the truck?
-Will it need a cross member to hold all the weight of that stuff hanging off the back of the engine?
-E-brake and speedo cables need extending?
-Performance wise are there any issues (weakness, popping out of gear, hard to shift, etc)?
Thanks
Questions:
Thanks
