school me on 80's
in the nappy dugout
what is the best year - 94-97? what makes one year better than the others? I am in the market for an 80 and want to make sure i get the most reliable/best for my money.....
why not get a 93 or older?
thanks
signed
retard
ATL SHAWTY!!!
I like my 93', I like my 97' better...maybe it is the lockers...i dunno.
Does the L on my grill and my rear door mean "locked"?
Smit
Although I'm far from an expert, 93 and up gets you into a more powerful engine, which most seem to prefer. Also, if you can get lockers - good for resale and even better for off road use. Of course, if you live in Canada, you can get the 1HD-T engine. Had to add that....
I personally like a '96 or '97 with OBDII and airbags ('95 with OBD1.5).
If you don't care about those things, then you can opt for '93-'94 w/o airbags, but with the larger 4.5 inline six, instead of 4.0 six of '90-'92).
Mot
stray far far away from a 91-92 slow as $hit. I have had a 91, 87, and now a 94. The 94 tops the others with more power by alot. I loved the looks of my 87 and its simplicity. The 94 has the same interior as the 91 but with bigger rims, fender flares, and about 60 more hp.
Noah said:
too easy.....:D
It's pretty easy to delete threads with questions from people who don't feel like searching:D
Come on Noah, then You can say "I learned how to use the search function today":D
You know I am half kidding, but only I know which half:flipoff2:
Although, in fairness to Noah, on this forum, on most questions, you get about as many opinions as answers! Although I like the variety of opinion, some don't. I think that's why new threads get started on the same old topics. Also, opinions do change over time, so don't be too hard on the guy....
Martin, we don't beat up on the newbs here in the 80's section. Noah use to start these threads about "what did you learn today". He is almost an old timer and just having a little fun.
We now will return to the tech theme of this section: From Slee's site that is linked in the FAQ
1991-1992
First major wagon body re-design since the 1980 introduction of the 60
series.
3FE 4.0L engine and A440F automatic transmission held over from the 62 series wagons.
Introduction of full time, four wheel drive system.
Introduction of all coil suspension for the wagons.
15" x 7" alloy wheels standard and unique to '91-92 but the same as SR5 mini-truck wheels
front disk / rear drum brakes with FF front and SF rear axles
third row seats available for the first time
no airbags available
no ABS brake system available
no factory lockers available
1993-1994
Introduction of 16" wheels.
Rear axle changes to full floater with disk brakes when equipped with ABS
Also gets viscous coupling HF2AV transfer case versus
non-viscous HF2A transfer case for drum braked 80's (and fj80's)
Introduction of 4.5l 24 valve motor.
Front and Rear factory lockers become an option.
Automatic transmission - Electronic Controlled A442Fwith mechanical lockup converter
Somewhere in 1993 the AC system changed from R12 to R134. With the R12 systems the dryer unit was in front of the battery and with the R134 it moved to behind the bumper. Might have been in 1993
The thickness of the drive plates on the front hubs were increased after April 1994 (build date). The new drive flange number is 43421-60040 and the old one is 43421-60022. This is important since certain after-market birfield joints were based on the earlier birfield. If you try to install an earlier birfield into a later truck, you will not be able to install the circlip on the end of the axle shaft.
Supercharger systems now available for 1993-1994 models.
Front ABS Lines are routed on the front control arm.
Radiator is a 3 row brass core.
1995-1997
1996 saw the introduction of the Lexus LX450 Model.
Exhaust system changed from side by side catalytic converters to in-line converters. The exhaust also routes below the frame rail just behind the catalytic converters to avoid excessive heat on the passenger floor-boards.
Front grill changed from the word TOYOTA written across the front to the new Toyota symbol.
Headlight mounts are different from 1991-1994 vs. 1995-1997 and will not interchange.
Redesigned dash board with airbags as standard equipment.
Headliner changed to two piece molded units.
Emission system on engine changes. Changed from a Mass Air Pressure meter to a Mass Air Flow meter. Certain plumbing was also removed.
Supercharger & Turbo systems available for 1995-1997 models.
ECU updates and truck became voluntary OBD-II compatible. Fully compatible in 1996 models.
Wheel Lug nuts change from conical to washer type.
Airbags become standard
Automatic transmission changes to the A343F. Some 95's were produced with the A442F. The transmission type is printed on the label on the driver door.
1997 saw the introduction of the 40th Anniversary editions as well as the Collectors Series.
1997 the rear swaybar brackets that attach the bar to the frame were changed from a plate side that attached to the side of the frame to a bracket style that attached to the bottom of the frame.
ABS wires on the front were moved upward and no longer run down the front control arm.
Radiator is a 2 row aluminum
Noah,
1993 is definately the year you want to look for. Don't worry about the reasons why that alot of these guys will give you just look at it this way. "Because I said so!";)
Get it..........
Good
reffug
93 with armor. Don't need no stinkin' air bags!
You know some people I'm sure would say that is a crazy comment but it is one of the things about my rig that I truly love. Its great to be able to put either one of my kids up front in there car seat and let them ride beside Daddy in the big truck. My son especially loves it cause he can see everything thats going on, what can I say the boy likes rocks.
Good on ya Doc.........:cheers:
Yep, I love it too. The wifey is a bit too short to be at a proper distance away from the steering wheel for air-bag deployment, so it's better for everyone anyway.
My '93 is best 80 I've ever owned.
Of course, it is also the only 80 I've ever owned :D .
I see the point about being able to put kids up front with the lack of airbags--my 3 year old gets to ride up front sometimes when we're off the highway. Seems like most modern airbag autos have a deactivation lock of some kind. Don't the airbaged 80's?
Also, isn't it accepted wisdom that the back seat is marginally safer than the front, anyway?
I'm surprised nobody has weighed in on the tranny differences. Seems to spark some entertaining exchanges now and again...
Hayes
I thought about stating how the 93 tranny is so much stouter than the other years but its Noah that I'm talking to here so I figured just telling him 'Because I said so!' was the best solution. Kinda like when your talking to your 3 year old, trying to rationalize with them is not always the best approach.
