Scarred spindle question
Idaho
A little long due to background
I just got the truck a few weeks ago (168,000 mi) there was some pedal feedback and steering wheel wobble on braking. Turns out the PO's brake guy but on an old bad lock washer that loosened and let the lock nut and bearing loosen up. :mad: (PO said warped rotor). I tightened back per FSM and posts here. There is still some pedal feedback due to uneven rotor wear but better than it was. Called C-Dan to get prices on rotors pads (now) and axle rebuild kit (winter project) he said look for scarring on the bottom of the spindle. Well that is exactly what I found. I measured with my calipers which are indexed to the nearest .01 inch and I could not detect any difference (interpolating between index markings) so I would guess less than a thousandth or two. I can feel it with my finger and fingernail but it is slight. With wheel bearing properly torqued I detect no play.
Now for the dilemma. I have some trips planned in the next few weeks (nearly 2000 miles) and want the brake wobble completely gone. I have limited free time between now and then.
Proposed order:
1) Replace rotors and pads repack outer bearings and go have fun (rotors are at min thickness can't turn even if I wanted to)
2) Get back from fun tackle axle rebuild, new spindle (if needed) new wheel bearings if needed, (will probably do wheel bearings anyway).
Questions
1) Can I put new rotors and pads on the existing spindle and bearings without risking uneven wear?
2) Does the spindle need replacing?
Thanks
you might as well replace the bearings rotor and pads as well as the seals all at once. i would either leave it for the moment and enjoy it, or just spend a good half of a day and get that side of the axle done. If your going to tear into it, you might as well get it done the first time.
As someone once told me: If you dont have time to get it right the first time, what makes you think youll find time to get it done the second time.
Actually, by the time you've torn down to do rotors, you're more than halfway to completing tear down to repack the axle. Others can chime in, but I think another 90 minutes and then you can rebuild with fresh axle grease, upper/lower knuckle seals and seals. I mention this because I wonder if the knuckle bearings are worn - allowing some of the wobble you feel.
As to your question replacing the spindle - mine have a wear spot on the bottom and the bearings snug up nicely so no need with mild wear. I think you can just replace the pads/rotors and be done for a while if that's what you must do. No matter WHAT you do, be sure the 4 knuckle studs/nuts on the bottom of the assembly are not loose. I'd bring tools along to check this at intervals on a long trip if you know the knuckle's in need of maintanance.
DougM
Thanks for the replies guys. Today I just dropped a bunch of coin ordering rotors, pads, bearings, seals and axle rebuild kit and belts. Thanks to C-Dan. I just need to decide if I can do it before my trips or deal with the pulsing brake for another month.
IdahoDoug;
Thanks for the info. The best way I can describe the feel is it is slightly less than sliding you finger over 2 pieces of paper on a flat table. I don't know the knuckles need maintenance other than the fact of the mileage on them. Really a PM thing.
I have been hesitant to top off grease (through the hole) in the knuckles as I can't be sure of the type that is in there now and I am nervous of mixing synthetic and regular.
Go ahead. Mix the greases short term. The right amount of the wrong grease is better than too little grease.
Your description of spindle wear is far less than what I routinely allow back ointo service on the work trucks. And they are Chevies. Clean it up with emery cloth or 600 sandpaper when you do your knuckles and run it til it wears out completely. :)
If your only brake concerns are a slight wobble upon application, rotors that are at minimum and pads near worn but not on the squealers, I'd run it. In fact I have. For a long time. No hardcore wheeling, but some mild trails and lots of freeway/streets. For much longer than a month
Oh, yeah, before I forget...
Repeat after me: "It's a combat vehicle. It was engineered to operate in combat situations." Maintainence can be put off for a bit, if necessary, without dire consequences.
