ScanGauge II - Cleared Codes REALLY Cleared?
jaymar
SoCal
So, when someone clears codes with the ScanGauge (P0420 for argument's sake), does that mean they're so far gone a California STAR station can't dredge them up? '95 LC with OBDII here. Thanks!
Yes but...
1) the ECU has to be in ready state which means driving for about 40 miles without a new code.
2) doesn't stop the code from going off again as the ECU does its check
Yes but...
Cool, thanks. Been a few hundred, maybe a thousand. Hypothetically, of course.
In regards to the system being in a ready state, does the scan gauge show what systems are "ready"? Seems someone mentioned you could have x amount of non-ready systems and still pass. I dunno, don't live in Cali, don't have ODBII and don't have emissions here for the 80 :doh:
Yep. What NLXTACY said. The code will stay gone on the dash BUT the vehicle will show the ECU is not in ready state and they will not even do a smog check. Automatic fail. You have the drive the vehicle until all sensors show ready and then hope the code doesn't come back before the smog. Your best bet is to clear the CEL and then cruise around the smog shop until you see all sensors come back on and immediately pull into the shop. Tried that once but it didn't work. The code kicked on during the smog. Good luck.
My cheapo Harbor Freight one shows each system and which ones are "ready". I don't remember what the allowed number is for systems not ready but it's a really low number. Any system related to emissions is going to need to be ready.
I seem to remember that too--that one or two things can be off. Also that they don't even plug into the OBDII on the 95 model year, because not all 95 vehicles have one.
Then perhaps with just the sniff test and no visual indicator of a CEL you could pass if you truck is running clean enough :lol:
Not sure about California, but in Arizona the 95 model is considered OBD I, since the OBD II system was not federally required until 1996 year models.
Not sure if the Scan Gauge enumerates the different tests, but some OBD-II scanners do.
OBD-II equipped 80s support 7 system tests: misfire, fuel system, "components" (not sure what stuff falls under that test), catalyst, oxygen sensor, oxygen sensor heater, and EGR system. After clearing codes catalyst, oxygen sensor, and EGR system show "not ready." Oxygen sensor changes to a ready state pretty quickly, at least for me. But catalyst and EGR can stay not ready for a long time, and especially EGR. Toyota issued a TSB about 14 years ago about some of these readiness tests, including the driving "pattern" you need to go through to get the EGR to show ready. Here it is:
For those who may be interested, '95 and older CA smog test measures five gases, the fifth of which (STAR smog guy says) is knock. Can't test that under load on a full-time 4WD (though I suppose you could if you had dual rollers on your dyno), so they do an EGR function test instead. Gas measurements taken during a two-speed idle test, at idle and at 2500rpm. Though the '95s are OBDII compliant (mine is, anyway), I don't think they even plug in to that. Will edit this later and add a photo of the smog cert, which details precisely what's being tested.
