sc install hg or not
Richmond ky
I have a 97 that runs great with 151k on the clock. hg has not been replaced. I am going to install a trd sc and debating on replacing the hg. i have read the threads but i am still debating.
part 2
if i install a hg, i will replace the plugs, valve seats, ect. does anyone have the specs on how to port the head to get full potental of the sc.
Bdyer -
I am planning on doing the HG on my '97 when I install my SC as well. I have all the parts...just need to get back to the States. I will be doing the injectors as well (having them cleaned and balanced). I am working on finding out the best place to have the head re-freshed as well. Landtank has a shop in his area he used on a recent build he may be able to provide you some additional details.
- Mark
My LC had 168,000 miles when I installed the S/C. Currently it has 173,300 and is still running perfect.
No signs of HG issues. I don't even have overheating issues that many have reported. However, with the Scangauge I can see exact temps, and I noticed that during very hot days in the summer I had a few degrees increase. I will be installing an Aux fan for this summer to compensate for this.
I did do the injectors at 168,000 miles
I had the head gasket replaced and also had the head ported, flowed and the valves blueprinted. I have no reference to another supercharged truck, but hope to have someone in my area do a seat of the pants comparison to theirs one day.
Eventually, when the build is done and I work out a few kinks ... I will get it dyno tested and post the results.
Rich
does anyone else have any experience with porting the head with a sc install.
I have 145K on the clock and I installed the S/C @141K. I have not had any problems either nor had any serious overheating issues. I do have 10K CST in my blue hub and my cooling system is pretty clean (I also don't drive in temps above 100* very often). The PO had the original HG replaced by the dealership at around 100K, so I didn't replace mine during the S/C install. Replacing the HG when you are doing the S/C probably is a good idea if is the original HG. I probably should have done the injectors too, it's on my to do list.
I was burning oil before I had my headgasket done due to the valves, and haven't burnt any oil since I also changed the HG because I didn't want it to go out on my on its own time and Robbie was available. I put the SC on it a year later.
I know someone who didn't change the HG before the SC and went about 40K miles before it finally went on its own time.
Not sure if that helps you
