SC idler pulley
Mine doesn't have a lip on it...it's smooth on both sides. Never had a problem with a belt coming off if that's what you're concerned about.
no lip on mine either. I think it might be a bit of a challenge or expensive endeavor if you try to source one through trd. What's wrong with yours?
I called it idler but it is the trd v belt pulley that is ribbes and does have a lip on both sides of the belt, it is made of plastic. Mine was missing half of one of the lips.I called Totota and they could only get it as part of a pulley set for the SC for a cool 400$$....found a replacement pulley that matched up perfectly at oriellys for 12.99.
Here's the link.
Gates 38009 - Belt Drive Pulley | O'Reilly Auto Parts
Gates - Belt Drive Pulley
Part Number: 38009
Line: GAT
•DriveAlign
•UPC: 72053284256
Warranty Info
1 Year Limited Warranty
It is listing for $18.99 in NC. Whats up with the 50% price increase versus your location?
I went and checked, all three of my pulleys have lips on them, nothing broke thank goodness. Are you talking about the idler pulley mounted on the block or the pulley on the tensioner?
Thanks for the part number - nice find.
The smooth pulley on the tensioner/idler assembley is the other one I am looking for. Mine is a metal pulley but the TRD install instructions show a smooth plastic pulley that looks similar to the ribbed pulley minus the ribbs and the lips.
I am taking it to the local O'Reilly to see if they have one of the same dimensions.
As far as being ribbed, my used SC setup has 3 ribbed pulleys; the main crank add-on pulley, the SC snub nose pulley and the belt drive pulley on the assembly (Gates#38009)
Well I found the idler pulley. It is, Gates #38020
http://www.oreillyauto.com/site/c/detail/GATE/38020.oap?keyword=38020
Part Number: 38020
Line: GAT
•DriveAlign
•UPC: 72053525748
Warranty Info
$23.99
Here are the pictures.
Also, the ribbed belt pulley #38009 has a thicker lip on one side than it does the other. This fat lip needs to face forward when installed to keep the ribs in line with the other pulleys. See pictures below.
Nice work guys. Good to know that there is an affordable alternative if one breaks.
