- Thread starter
- #61
I took today and tomorrow off from work to hopefully button up some of the outstanding stuff.... some good and some bad.
The bad. I had previously ordered a full 5 piece TRE kit for an FJ40 (LHD) from Amazon. As previously mentioned I thought I needed 4 of them, turns out I needed 3 plus the appropriate drag link to Saginaw end... no biggie.... until I went to install the drag link today. Turns out the kit that was sent to me was a RHD kit - and I have the wrong TRE/drag link piece (as in, the tapered end on the passenger rear TRE is wider in the back than front.... it should be flipped around on the left side of the axle.... RHD....).
So that seriously pissed me off since I can't steer this stupid thing out of even my garage......
On to the good... definitely made some progress on the coolers but will wait to post anything else until I have the lines cut appropriately to length and hooked up.... the one teaser pic will have to do...
On the plus side for steering..... I did manage to (after lots of swearing and annoyances) get the steering shaft support bearing installed (via fabricated bracket which bolts to the frame).
At least for now... the steering wheel feels super smooth and there's zero droopage in the shaft like there was before (and no clamp on the saginaw box end of the shaft). I was concerned about the smaller bolt which holds the bracket to the frame until I thought about the physics of it....
The shaft wants to drop down due to gravity, but the bearing is mounted so that it's pushing the shaft upwards.... it's pushing that bearing upwards against the bracket, against the frame.. so really, all the bolt has to do (since the bracket is square tubing and 3/8" steel bar) is hold the position of the bracket against the frame.. there's essentially no lateral (side to side) movement possible due to the bearing support shaft and how it was built.... I'm actually happy with the outcome....
We'll see once dirt starts to get into crevices...
