SB adapter/bellhousing
Buxton, ME
Anyone know of an older adapter/bellhousing that was steel?
I bought a project that has new 350 crate motor installed, but can’t find info on the setup.
I am going through everything before I continue the build.
Wondering if I should get a new setup before continuing if I can’t find anything out about this .
Homemade??
Bad photo, but maybe it will help.
Thanks
i have a similar one here made by advance adapters i prefer the old style downey one with the inspection cover
So Advance Adapters made them out of steel in the past?
Maybe I could get info/instructions from them.
I’ll try calling them later today.
Thanks
Looks like a Lakewood scatter shield bellhousing. If done correctly it could be OK. If not, it will be trouble. Holes needed to be drilled in proper locations to center the trans to the crank. How's the pilot bushing look?
Pilot bushing is good because it’s never been used. Bought this mid-stream of their project as a rolling chassis.
Just makes me nervous now that I know a little more. Compliments to this site!!
Might have to throw down some cash for a new kit from AA.
Any benefits over the two options?
Keeping transfercase in factory location or moving with new driveshafts.
It's incorrect that AA sold those scatter shield bellhousings, but they had no provision to machine aligning the tranny to the engine (bolt pattern only, which is .016-.019 out of alignment). You could check out my ebay #263895845784 to see a better choice- - -just saying.
I like and and have ran the AA bellhousing in the past. I've heard good things about Downey's bellhousing too, if you can find one. They are ready to bolt up. Regardless of which one you use, the drive shafts will have to be altered if the engine is located correctly. I'm sure Downey will chime in at some point.
Seems to me you need a Downey V8 installation instruction manual, two choices: 1. Find the Downey instructions hidden here on Mud under the Downey Off Road link, or 2. send me your snail mail address for a freebie copy- - -easy deal.
Thanks for just saying.
I just bought it!!
here we go again i bought mine from aa and its in thier catalog that i bought mine from in the 70s, .nothing wrong with the steel unit except its hard to seal
I believe I did find it last night while searching at home, but would prefer paper over photos. Thank you
here is the aa belhousing i bought new in 77 still have the catalog .notice the alignment pins
Like I mentioned, the the alignment of the trans input and engine crank is only as good as the person or company altering that style of B/H. My guess is AA bought steel scattershields and altered them for the V8 conversion, in the begining . They are fine if done correctly. I've run across many that were done by an individual and were drilled wrong and the opening was hacked. My AA bellhousing was purchased in the early 80's and is casted unit.
back in the day i used many downey products all were good i didnt care for the holley carb but other than that sowneys stuff was good
In the 1970's AA did not have CNC equipment (nor did Downey until the early 1980's), so they had no way to machine align those dowl pins (i.e. the milling machines that knew where dead center was on the Chevy crankshaft as it determined the dowl pin locations on the bellhousing).
Everybody who had a Holley carburetor "without" the float bowl baffle and metering block chimney didn't like their Holley in off road terrain, those who did have the parts loved their Holley's. See ebay #254041028091 explanations and drawings for a better explanation.
In the 1970's AA did not have CNC equipment (nor did Downey until the early 1980's), so they had no way to machine align those dowl pins (i.e. the milling machines that knew where dead center was on the Chevy crankshaft as it determined the dowl pin locations on the bellhousing).[/QU
In the 1970's AA did not have CNC equipment (nor did Downey until the early 1980's), so they had no way to machine align those dowl pins (i.e. the milling machines that knew where dead center was on the Chevy crankshaft as it determined the dowl pin locations on the bellhousing).[again old news they worked for lots of folks and are still in use after 40 years so something must have been right
Is that a 3-spd tranny? If you’re interested I have a conversion setup i took out of my 69 that uses a GM truck belhousing and a plate to mount to the tranny. It also has a turned down input shaft housing for the proper throwout bearing.
Let me know if you want me to drop it into the “mail”.
