sand run break down
Well,
two of us went to a local sand dune area here in centeral oregon. Jeff's cruiser has 350, on one of the climbs his diff. traveled too high and broke the remote oil filter housing. has any one else had this problem? the filter is located on the right front fender.
Tuff s***! That's what you get get for modifying whats once was perfect:rolleyes:
Uhhhhhh,....I'm not quite sure that was the constructive "feedback" he was hoping for
Man - I've run across some GREAT posts from you this morning. :rolleyes::rolleyes:
Could you reposition things a bit to prevent this from happening in the future? Also, could repositioning bumpstops prevent your diff from traveling too far upwards?
If that happened in the People's Demokratic Republik of Kalifornia, where I live, the enviro-nazis would already have you in prison for that hazmat spill on an "environmentally sensitive sand habitat area".
Doubtful. Most knowledgeable Cruiserheads don't put the oilfilter in the same place where the differential will be. Now clean up that oilspill....
and those shoes..................
sheesh
wow
I guess that I expected to get some constructive help on this!!!!
The filter is remote and located on the firewall the bracket that screws to the oil filter stud has two fittings, would there be a problem placing 90 degree fitings instead of strait ones. this might gain the clearance that is needed. Any 350 converts out there run into this problem? What did you do?
My advise would be to ditch the remote adapter and keep the filter in the stock location. Easy to get to, no clearance issues. Also, you'll be removing potential problems(leaky hoses and fittings) for the future. To me ,changing an oil filter mounted on the firewall is harder than underneath, anywats. Good luck:beer:
Those bib lights are hideous.
If you were to ask me oregoncruiser, it sound like you are getting constructive criticism. Funny huh, about the enviro comment considering we are the enviro state! Thought it a good idea to dig a hole in the sand for the lost oil. Covered it up after you finished I hope. Biological agents will eat that stuff after a while but it might be a good idea to bring something to deal with any potential oil spills in the future. Tread lightly! Hmmm, note to self, oil absorbant, tarps...
As an armchair, Monday morning tree-hugger, I would line that hole with a garbage bag until the oil leak has been secured. Then use the pump out of my 90 weight jug, pump the oil collected in the plastic-lined hole into a suitable transport container. Or, lift the lining out of the hole, with the oil puddling in the middle, and shovel the oily sand that you made into the puddle of oil in the trashbag...double-bag that and pack it out. I don't put much faith in microbes eating my old oil.
That blows dude! Now, if the differential actually hit the adapter housing where your stock oil filter would normally go then I think even putting a filter back in the stock location would result in the same situation.
Post a pic of the motor location in the engine bay (taken so we can see where the point of contact occurred). I've never even heard of a 350 oil filter being hit by the differential. I thought that all the 350s had the oil filter in the back of the motor. How is his on the front near the diff?
If it is up front then I'd recommend adding a little to the bump stops (put in a spacer plate) and maybe if you have the type of motor mounts that allow it then add a little bit of spacers to move the motor upwards.
As for the pic, remove or edit the one with "evil stuff" everywhere. Just doesn't illicit good or helpful:rolleyes: responses from the peanut gallery:doh:
A single, 90* fitting should not effect things much. Trust yet verify: check with a gauge before and after and evaluate.
I am also a bit perplexed. I am running an sbc with shackle reversal. The only way the axle housing or anything related to it could come in contact with the oil filter is a catastrophic failure of the springs or their attachments! Please do post up the pic(s) requested above so we can see the situation. Any chance the engine is a ford? some of them had filters more towards the front.
Not trying to rattle your cage just curious.
It just occurred to me that the oil is leaking on the passenger side (right). SBC oil filter is on the left side as seated in the cab! Are the oil lines running under the engine? If so, The axle/differential likely impacted and dragged the oil lines putting side forces on the filter relocation fitting.
Relocate the filter back to the driver's side (US convention). Cut back the oil lines to get rid of the excess and be happy.
How the fxxx did a diff hit anything on a firewall?!?!?!?!?!?!??!:rolleyes:
