- Thread starter
- #21
Had to google it. Straya=Australia? This is like saying 'murica? If so, you should actually spell out your location to help people understand and answer your question. I am a bit of a geography buff and here I was thinking you lived on some tiny island I never heard of
Anyway, I'm pretty sure there are plenty of people running 35's or 315's on 80's in Australia. I always thought the rules were basically bolt-on parts are fine, but no DIY welding on the frame or axles, or something like that. Why the Australian 60-series guys never go SOA.
More to the point, 35's because they look good. As others have said, if you're thinking about it, you'll probably end up doing it at some point anyway. There really isn't much of an advantage off road--I have run many trails that people think require 35's with 265 tires, but they do smooth out the ride a lot off road. If you're looking more for what's practical over what's cool, then 255/85/16 is probably the best.
Haha that must be the first time I’ve heard someone not know what “straya” meant.. it’s the bogan way of saying Australia (I wish it was an exotic island somewhere).
In terms of legalities, it’s pretty strict here. Tyres can only be 2” above stock at maximum. Maximum lift is 50mm as well. Bars/lights can’t be taller than the bonnet/hood line, etc. heaps of dumb rules. I’m thinking if I switch the placard out to say it had 33’s stock (probably believable for an untrained cop) then the 35’s will do fine.
seeing how you're in Australia, any chance you could try some half life 35s see how you like them?
What condition are the tires in now?
Considering it is your 4th car and you're considering 35s that seems like the size to recommend but I'd be happy with some 255 85 16s. Something else to think about is going up a rim size as 17 inches has become quiete common (at least here in N.A.-that's North America, so there's the chance of running into more tire choices but also finding a spare easily, or a secondary set off some pull offs if you needed).
Current rubber is about 70% front 60% rear.. I could probably swap for a set if I could find someone that wanted stock rubber.. I think they’d be few and far between though.
I’ll be buying a set of sunraysia rims to go with the new rubber, so could go up to a 17 if that’s the way to go.
I've seen it as Straya a few times. If you think of how a "typical" Aussie might pronounce it, you hear Straya in your head. Or O.Z.
Spot on haha
