same engines different chain tensioners?
Rio Rancho, NM
Attached is an image of original chain tensioner and donor engine tensioner next to each other. Can anyone tell me which is OEM?
The one on the left is the early design used from September of 1992 to June of 1993. The one on the right replaces it.
Thanks so the one on the right is better designed...and should be the one I reinstall in frankenstein engine?
BTW you guys rock and if your still on mud real time....can't get service bolt holes on exhaust cam to line up....any tricks? The head I took off my engine i don't remember this issue.
Put it in before taking the chain off. Think you can take the extra large channelocks put them on one part of the gear to turn it enough to get it in. There's a spring against it. If not try a screwdriver pivoting against the head to carefully pry the gear. It should remain stationary with the cam installed and the valves applying resistance.
thanks, FSM had me take chain gear off just prior to this cluster...
