Salvaging Ed
WWYD: What would you do?
  • Build a buggy
    Votes: 0 0.0%
  • Dismantle into the largest stockable component possible
    Votes: 3 21.4%
  • Sell all the parts and use the cash for mods
    Votes: 6 42.9%
  • Break it down to "project" kits
    Votes: 1 7.1%
  • Raffle the parts and donate proceeds to local Cruiser group
    Votes: 1 7.1%
  • Scrap it
    Votes: 2 14.3%
  • Something else
    Votes: 1 7.1%
  • Total voters
    14
MDarius
I break stuff.
Bountiful, UT
I've decided to salvage my wrecked 95 myself. I'll be replacing him with a locked 80 series very soon (stay tuned!). My time availability has opened up for the next couple of months which should be just about right.
Here are pictures of the condition of the 95:
https://goo.gl/photos/oG6XVgFw4J67vDpP9
- The frame is tweaked.
- The front wheels won't turn L/R AT ALL.
- The sector shaft is sheared
- Obviously front PS corner is trashed
- Fan is pushed slightly into the radiator, rad seems in tact still.
- CDL only
- Other damage as noted in pictures and yet to be seen.
228,000 miles on it. Well maintained up until 190k~ish, then I wasnt home much and my teens started driving it. After that, oil changes were more sporadic and only basic maintenance was done. I looked at my records and I did re-baseline at 210k~ish. Anything that needed to be fixed was. Interior was modified by my 80 pound Akita and 4 kids, less than perfect.
So, with all that back story, what would you do with it? What is most relevant or key to save for myself? I read posts about parts becoming less available and it makes me a little nervous.
I'm thinking of dismantling it and putting all the parts in LX approved vacuum sealed bags until I need them for the next rig. ;)
Dismantle after you get it's replacement.
No sense searching for what you had.
Do you have space to store the parts?
I have a storage unit with room to spare, just not enough for the entire truck. With the steering locked up its immobile without a trailer.
Also I have 4 drivers, 4 running cars, and 4 parking spots. No garage. For now. I need to clear it out (frame and body) soon.
I'm In the same position because I rolled mine in December. I already purchased a replacement vehicle. I shopped for one with no rust and straight body with and electrical system that was not compromised. I was not concerned with interior or even the drivetrain so much because I will swap all that stuff over from mine and sell the elocker axles. I plan to stock pile most everything else for my own future use then chop up the wrecked body for sure and the frame unless someone buys it.
Not sure if this plan would work for you but there it is. Good luck.
OK, I need some help. This thread didn't get much traction. My plan is to dismantle the 80 by systems. There will be parts I want to keep, because I know I'll need them. There will be parts I don't want to keep and will post in the classifieds when I'm done pulling everything. I need to get it out of my driveway.
I expect to get some totes, bags, boxes, etc. and store and label the parts and systems. I'll keep an inventory list and know what I have and where it's at. I'll have my sons pull the parts and they can keep the money we make off them. This will be an incentive to not break things, and to get it done.
So, with that in mind, what do I need to be thinking of that I'm missing? Where would you start? I'll start with the parts/systems I know I need (ABS parts), then move on from there. If I drain all the fluids will I be causing a problem? Is it better to store a differential that's full of fluid? These are things I don't know.
