Saginaw PS Bracket Build
Louisville, KY
My power steering pump was leaking like crazy and after removing I was reminded how cobbled the current bracket was from the PO.
I decided to fab up a new one that didn’t utilize the smog pump bracket as the pivot but instead mounted to hole pattern on the block (where the smog pump bracket used to connect) and the pump pivots on the new bracket.
I designed them in onshape the cut it out in the waterjet.
Tacked it together to check fit.
Fit well on the truck so I welded it up and ground the outside welds flush.
Then powder coated it.
Pump fit up
Ready to install back in the truck tonight!
Thx for the interest guys. I love designing and fabbing parts. Happy to build another batch once I am confident that this one is rock solid. I’ll have to figure out batch size etc to get s decent price. More to come.
@Casey E
Got your pm. Shot one back
@greenbeasty
Can definitely make more. I want to get this one installed and tested to see if I need any additional design changes prior to making a batch.
@firefighterjed
Yes, it mounts on the drivers side. It uses the smog pump mounting holes on the block (slides under the engine mount). I’ll post up some pics after getting done with the install.
Thanks blue.
I’d be interested in buying the parts right after water jet. I can weld and powdercoat. That would make shipping cheaper too since they’d fit in a flat rate box.
Hmmm. And I’ve been offering a smog pump located PS bracket with a special MUD deal price for like 15 years now.
Sounds like a marketing problem;)
You have a good looking part there’s. I’m guessing You also carry a tensioning bracket that connects to the thermostat mounting bolt? Your bracket does not look like it would have mounted to my pump. What model Saginaw does it mount up to?
My bracket is specifically designed for the Saginaw ‘ham can’ pump you are using. The spacing of the front and rear ears was designed to allow greater fore and aft placement for pulley alignment than other brackets people were using.
The adjuster bracket I offer utilizes a water pump bolt, just as Toyota did for the F engine alternators and the 2F air pumps.
After10 years of marketing the first iteration, I modified the design based on user input to make the bracket more user friendly for FJ55s as well. But I retained as a primary objective the need to keep the pump as low as possible to retain the ability to put the pump in on F engines that utilize the large driver’s side air cleaner.
And yes, I don’t spend nearly enough time promoting the many products I’ve designed over the last four decades.
And if I were better with the search queries, I could point you to threads in this forum with pics of my bracket installed. Every time I see one, I feel like a proud papa. Just like I do with my shackles.
I think the oldest pics I remember were posted by @Outback
Trying to check yours out. Can’t definitively find the item on your site. Is it this BKT?
@Casey E
What kind of problems did you have with the other brackets? Send or post a pic of your current setup (including clearance to your exhaust manifold). I’d also be interested in seeing how you have your belts hoses routed. I can always tweak the design a bit for your setup if needed.
Another update. I tested for flex on the bracket. I reved the engine and bounced the wheels against the stops to load up the pump/bracket. It held strong and stiff. Here is a quick video. PS Bracket Test
